Results 1 to 2 of 2
Thread: 3 bar Map Sensor
    Dec 2007
    Default 3 bar Map Sensor
    Anyone have a part # for the 3 bar map sensor that works with the E38. Or even an application for another vehicle that will work.
    David McLain
    www.etdrag.com
    Junior Member NERDPWR's Avatar
    May 2007
    It blows when nobody has the right answer.. Guess the presumption is everybody can use the search function..
    You probably have the info you need now but during my very limited experience with boosted applications I found the LS9 3 Bar map to be the goods..
    GM Part: 12592525
  1. 2 bar map sensor
    By VYSSLS1 in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: February 1st, 2011, 05:11 PM
  2. 3 Bar MAP sensor doesn't work with 3 Bar scaling!
    By Redline Motorsports in forum General (Petrol, Gas, Ethanol)
    Last Post: April 27th, 2010, 05:21 PM
  3. Anyone know of a 1.5 bar MAP sensor?
    By mistermike in forum General (Petrol, Gas, Ethanol)
    Last Post: August 19th, 2007, 08:57 PM
  4. 3 bar map sensor
    By Delco in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: March 5th, 2007, 07:18 PM
  5. 2 Bar Map Sensor?
    By caver in forum General (Petrol, Gas, Ethanol)
    Last Post: September 6th, 2005, 05:56 PM
