Results 1 to 10 of 18
Thread: 06 Z06 Chassis Codes
    Sep 2010
    Default 06 Z06 Chassis Codes
    I was under the impression that the Flashscan V2 would allow me to read chassis and body codes. Am i wrong or is there a chance i am doing something wrong
    You have to configure it... in S&T software, go F5 Black Box Settings, select Tune Settings tab, on far right checkmark the 4 DTC types... then Save to file, then Program to V2.
    Then when V2 is connected to vehicle go F3 Diagnostics and try the various menu items.
    Sep 2010
    OK so i have it configured now and it comm. with every module on a 2000 GMC sierra but when i hook up to a 2006 zo6 corvette or a 2009 Silverado i only get comm. with the engine and transmission?
    Try with the scantool (i.e. on laptop), see what modules it sees.
    Sep 2010
    Yea hook up with the laptop connect and validate modules the 2000 sierra shows Ecm,tcm,bcm,ebcm,ipc everything but do the same on the 06 vette and 09 Silverado only get ecm, tcm.
    Sep 2010
    So is this an issues of the E38 ecm and the CAN network since it works on other vehicles. and i see some of the code stuff says not available for the CAN
    Do you have these RPO codes: F55, UE1...?
    I'm still trying to make sense of the schematics, see attached...
    it looks like there are two buses (Class2 and GMLAN) joined by a gateway (BCM).
ID:	9038   Click image for larger version.
ID:	9036   Click image for larger version.
ID:	9037   Click image for larger version.
    I'm not sure why you can't access suspension/chassis codes... I thought anything on the same bus as the ECM would be able to have it's codes read.
    Here's descriptions from the Service Manual.
    When tried it with the scantool/laptop, goto Edit->Properties->Advanced->Diagnostic Trouble Codes, and make sure there is a checkmark next to Check/Clear DTC's for All Modules.
    Sep 2010
    Yes there is a check mark next to Check/Clear DTC's for All Modules. But still only connect to ecm trans and no i dont have RPO codes F55 or UE1
  1. 3000 RPM max and setting codes 03 Z06 with Magnuson at 150kPa
    By TurboCamaro in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: September 28th, 2010, 08:12 AM
  2. Using Flashscan V2 with LS1 Engine Swapped to Older Chassis
    By Mikey 97Z M6 in forum General (Petrol, Gas, Ethanol)
    Last Post: January 31st, 2009, 07:55 AM
  3. Looking for PCM P/N for L21 454 (99 P12 RV Chassis)
    By N0DIH in forum Vortec V6/V8 Specific
    Last Post: August 20th, 2007, 04:54 PM
  4. Replies: 5
    Last Post: July 28th, 2005, 03:26 PM
