Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: 06 Z06 Chassis Codes
  1. #11
    Sep 2010
    So is it safe to say that the V2 wont comm. with anything but ECM,TCM on a E38 ECM on CAN network?
  2. #12
    Quote Originally Posted by Ralf"s Rides View Post
    I'm not sure... does your 2006 Z06 have these RPO: F55, UE1...?
    PM me your VIN, I can look up if you have those.
  3. #13
    Sep 2010
    here is the VIN 1G1YY26E865132583 But i already have a RPO list from the Stealership that does not list F55 or UE1
    Plus i get the same result when i hook up to the boss's 2009 Chevy silverado with the E38 on CAN
  4. #14
    PM me the VIN of the Silverado also.
  5. #15
    Sep 2010
    Silverado VIN is 1GCEK29059Z173665
  6. #16
    If the 2006 Corvette doesn't have F55 then the suspension controller is not present... but the BCM and ABS controllers should be able to communicate.
    I couldn't get a list of RPO's for the 2009 Silverado.
  7. #17
    Sep 2010
    ok when i try to validate all on board OBDII modules it searches for engine and transmission controllers only. Here is a screen shot of the scan tool when i try to validate modules. i get the same message on the 06 vette and the 09 silverado. Everything is configured as described in previous posts, all software is up to date V7.5.6 build 133 V8.1.2 build 115 Bootblock V2.06.03 Firmware is V2.06.41
Name:	Scan tool Screen Shot.jpg
  8. #18
    That is correct, in V7.5 software only engine and trans controllers are supported when using CAN mode.
    To see/scan trouble codes from other modules, use the on-board FlashScan F3: Diagnostics menu.
    When the V8 scan tool is released it will fully support all modules.
  1. 3000 RPM max and setting codes 03 Z06 with Magnuson at 150kPa
    By TurboCamaro in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: September 28th, 2010, 08:12 AM
  2. Using Flashscan V2 with LS1 Engine Swapped to Older Chassis
    By Mikey 97Z M6 in forum General (Petrol, Gas, Ethanol)
    Last Post: January 31st, 2009, 07:55 AM
  3. Looking for PCM P/N for L21 454 (99 P12 RV Chassis)
    By N0DIH in forum Vortec V6/V8 Specific
    Last Post: August 20th, 2007, 04:54 PM
  4. Replies: 5
    Last Post: July 28th, 2005, 03:26 PM
