Results 1 to 5 of 5
Thread: Need help - Can Start Car, but dies when I give it any throttle before going to CL
    Sep 2007
    Question Need help - Can Start Car, but dies when I give it any throttle before going to CL
    Alright guys I have been at this for far too long. Have 2000 TA with a 383 and Fast 102/PTM 92mm intake. I have the car starting up fine and it runs great once it gets to closed loop, problem I have is when it is dead cold and I start it, it will give some trouble, but comes to idle. Also if I give it any throttle at that point in park or in gear it will just die. After the car gets past 140 coolant temps it is fine. Another thing I have to do when it is cold it take fuel out of the PArk to Drive enrichment table to get it to not die going into gear. All of the fueling looks good. It is driving me crazy. Who want to wait for the car to warm up or get into closed loop. 15-20seconds is a long time when you are just sitting there....LOL I have attached the tune. Please help.
    Sep 2007
    Car has a 232/236 112 cam, It is an A4 with stock stall as well.
    Jul 2008
    You might have more luck manipulating Table B3605 if you are wanting to take fuel out during start-up. Try an EQ of 1.00 and see how that works.
    If you are really wanting to go to closed-loop faster, you could change B4202 to 1 second. I see you you have lowered your Closed-Loop Temps to 10C. Problem is that the O2 sensors are very lazy when the engine is that cold..but if you are wanting to get to closed-loop quicker, change that timer or try changing your OLFA Table to lean it out some.
    Hi Mr Z,
    Have you tried working thru this: showthread.php?4661-Idle-Tuning-Helpful-Info-Inside
    Jul 2008
    Mr.Z:
    Also, started a new thread on Idle Tips & Tricks that may be of interest to you..http://forum.efilive.com/showthread....ips-amp-Tricks
    Good luck!
  1. Car Dies with IAT plugged in
    By laughatrice in forum Gen III V8 Specific
    Last Post: June 10th, 2009, 06:26 PM
  2. Car dies when I turn on the A/C
    By Powerhouse in forum Gen III V8 Specific
    Last Post: July 29th, 2007, 01:05 PM
  3. Car Dies With A/C On
    By vetteboy2k in forum Custom Operating Systems
    Last Post: July 27th, 2006, 02:31 PM
  4. Car dies when i hit the clutch...Little help plz
    By killaz in forum General (Petrol, Gas, Ethanol)
    Last Post: June 12th, 2006, 11:32 AM
  5. Car just dies
    Last Post: April 8th, 2006, 05:05 PM
