Page 6 of 7 FirstFirst ... 4567 LastLast
Results 51 to 60 of 64
Thread: Idle Tips & Tricks
  1. #51
    Paste (i.e. no multiply).
  2. #52
    May 2007
    Thanks Joe. I'll try that. It's pretty good driving now but I've learned so much lately ill keep trying things
    2000 NBM trans am.
    427 Dart ship block,Lme ported Ls7 heads 12.5 compression
    246/262 .730/.712 112+4 low lash solid roller
    Rmvb 4l80 with transbrake, 8" FTI converter
    12 bolt Moser rear end with 4.10 gears
  3. #53
    Quote Originally Posted by Aint Skeered View Post
    Good job
    I find I'm learning new things about this all the time.
  4. #54
    Nov 2014
    can someone point me to weatrhermans "idle tutorial"? for the life of me i cant find it. (iv seen sspddmons.)
  5. #55
    Feb 2006
    https://forum.efilive.com/showthread...in-single-log)
    This is his work. You can start here. There is good info in this thread.
    Al
  6. #56
    Al, thanks
  7. #57
    Oct 2016
    Just want to chime in here and add 2c, hope it helps someone else.
    Iv been scratching my head for the last 3 weeks desperately trying to idle tune my 6L with 92mm cable throttle running the LSA TVS 1900 blower with the LS1b pcm. After following the idle tips and tricks tutorial and hacking multiple tunes I still wasn't getting any results. No matter how much I hacked my idle settings mentioned in the tutorial or how many times I performed RAFIG nothing had any direct influence on my idle tune quality and it would stall frequently. That was until I modified my IAC effective area (B4403). If you change your TB or IAC motor from stock nothing seems to work correctly if your IAC effective area is not close. Maybe this is mentioned somewhere but I seemed to have overlooked it.
    Great forum, thanks for the info and contributors!
  8. #58
    Aug 2013
    Quote Originally Posted by jeffro View Post
    It was mentioned somewhere in this forum, and there also has been talk about it in other tuning forums... but any talk about it has always been somewhat vague. I remember reading comments like "you need to line up all your airflows" and "you need to shift your IAC effective area table", but I can't remember anyone posting an actual method.
  9. #59
    Mar 2009
    Well this explains why the RAFIG didn't work for me, it spit out lower than stock numbers the last time I tried it. Going to try this once I fix the fire hazard fuel leak. Can someone clarify why effective IAC area matters on a cable throttle when you go up in size? I did bump the 3500 up to an 85mm TB and it idles all over, but I'm pretty sure that's just because I haven't touched the idle from the mishmash crap I dropped in there in the first place. If you put the stock IAC back into any TB is really shouldn't matter, right? I realize the larger blade may flow more at idle, but then again its bypass hole might be smaller too (haven't checked). I can totally understand why a drive by wire car would be affected by this. Or is the effective IAC area only applicable to DBW cars?
  10. #60
    The new TB has different cross-section area on its IAC passage...
  1. Underdrive Pulley & Now A/C Does Not Work at Idle
    By SOMhaveit in forum Gen III V8 Specific
    Last Post: July 6th, 2010, 08:50 AM
  2. idle tuning & airflow
    By ZL1Killa in forum Gen III V8 Specific
    Last Post: October 14th, 2009, 07:47 AM
  3. RTACS tricks and tips................
    By Redline Motorsports in forum RoadRunner Real-Time PCM Emulator
    Last Post: April 25th, 2007, 12:27 PM
  4. LS2 Tuning Experiences & Tips
    By oztracktuning in forum Gen IV V8 Specific
    Last Post: November 23rd, 2006, 11:45 AM
