Good work guys.
Cool bananas. So you know exactly what the problem was or did doing the grounds over meet with that sound of an engine coming to life?
If you have a meter, dont forget to check if the battery is charging at 13.5V plus immediately from start up. These truck based tunes sometimes dont charge at all or delay too long. When I tested your tune it did not switch the alternator on.
Dont forget to mention on LS1Tech how much help the EFILive crew gave you!
It was the grounding that finally turned it over but it may not have gone with out the tune. Yes you all are up on the board at LS1tech too. Congrats.
Thanks for the tip on the alternator. Will check it.
Alt looks good.
First running log...start 2.efi
Good job... ..."I love it when a plan comes together"
Nicely done, sounds awesome !!!
Regards,
Taz
