Results 1 to 6 of 6
Thread: LS1 ECU question
    Sep 2010
    Default LS1 ECU question
    I am working on a custom project and would like to use '99-'02 LS1 harness and computer. The catch is that this is for a 4 cyl application. Is there any way to keep 4 cylinders from firing using EFI Live? I am not particulary worried about firing order because I can pick and choose what coils to hook up but the real issue is how to keep the computer from firing the remaining 4 which would cause a delay.
    My reasoning for using the harness and computer from a LS1 is for its simplicity and it is basically the closest factory computer to a stand alone system.
    The motor is a Ford Duratec (newer aluminum version) and T-5 transmission
    Thanks for any input
    Mar 2007
    The big problem would be in getting the crank / cam position sensors to work (i.e. - 24X and 1X signals). Otherwise, you could probably just not hook up the "extra" coils / injectors and it should work OK.
    Sep 2010
    Right, and that was the first thing I thought would be the major hold up but I I was able to relocate a factory relucter wheel onto the crank pulley and use a factory 24x pickup. Don Kinder from Slowhawk Performance said the delay of the comp trying to fire the other cylinders may cause problems.
    Hmmm you honestly are probably better off using an E37 or E67 ECM to control a 4 cylinder motor. I was thinking about suggesting a 97-04+ 4cyl PCM, but they're like my P10 I6 and a PITA to work with. The E37 is only used on 4 bangers plus the 4.3L V6, the E67 ran some I4s but mostly V6/V8s. Both can be run without a BCM if you apply the VATS patch, just like the LS1 PCM. But, I forget what input trigger the E37 uses, the E67 uses a 58x reluctor.
    Jul 2003
    Interested in a project like this... Why issues with the delay? all you have to skip is certain cylinders and that is it? Or am I mistaken?
    Mar 2007
    Quote Originally Posted by Highlander View Post
    It will be looking for the delay time between each cylinder and the missing cylinders nt firing will delay the time it take to see next trigger and think its a miss fire it will go int limp mode and start blinking he cel
    1972 Chevy Blazer, Twin Turbo Duramax 6.6
    69 Maro TT 427 LSX, Wayne due Vett frnt sub,
    Lateral Dynamics 3 link rear, D 60,
    T56, 18X10' 18X12 Boze Forged Speedsters,
    13" wilwood 6 pot fronts 13" wilwood 4 pot rears,
    (all Still under construction)
  1. question 2001 and up ecu in a 99 and down f body
    By AllOutPerformance in forum Gen III V8 Specific
    Last Post: June 15th, 2010, 11:38 AM
  2. Gen3 LS1 ecu
    By jbehe in forum Gen III V8 Specific
    Last Post: May 6th, 2010, 10:27 AM
  3. Question about A4 trans temp sensor for LS1 F-body
    By Joel_SS in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: August 24th, 2006, 05:18 AM
  4. LS1 to LS2 knock sensor question
    By Redline Motorsports in forum General (Petrol, Gas, Ethanol)
    Last Post: April 26th, 2006, 01:09 AM
