Results 11 to 20 of 27
Thread: A few problems
  1. #11
    Does it show FlashScan V2 under USB devices? If not, try another USB port. Update the drivers (Windows) or the firmware (EFILive software)? Open V8 S&T, then click the V2 logo that pops up near the clock on your screen and update the bootblock first, then the firmware.
  2. #12
    Sep 2010
    yes it show the flashscan under serial bus controller.now not trying to sound dumb but im not up to date with the technology lingo...explain it to me a little easier please!
  3. #13
    Well that means it is connected to your PC and the driver was properly installed, have you been able to read your PCM/ECM out from your vehicle now using V7 Tune tool and pressing the green arrow? When logging in V7 scan tool, did you select the proper PCM/ECM when you pressed the green button?
  4. #14
    Sep 2010
    yes i can read and update my truck using the v2 but i have to keep ung.plugging the usb and plugging it back in to make it work.
  5. #15
    Oct 2004
    Do you need to reconnect because it is disconnecting? Do you see the device disappear and then reappear in Device Manager? I'm not getting a complete picture from your posts so am having to try and read between the lines :(
    Did you try Blacky's changing/checking the cable type in the Scan Tool?
    Andrew
    EFILive Crew
  6. #16
    Sep 2010
    i am doing this because it is not getting power from the usb.it will not power up the v2.
  7. #17
    Oct 2004
    If you have tried different USB ports, cables and perhaps a different computer and it won't boot (after drivers are loaded) then it probable that the FlashScan V2 has a fault. Can you confirm you have tried a different USB port, cable and computer?
    Andrew
    EFILive Crew
  8. #18
    Also, dont plug the V2 into anything but an actual USB header on the motherboard. IE, dont plug it into a USB hub.
  9. #19
    Just to clarify, a USB hub is ok to use but only if it is a self powered hub. i.e. only if the hub has its own power supply that you connect to a wall socket.
    FlashScan will not work with a USB hub that is powered via the USB connection to the computer.
  10. #20
    Ah ok, I just make it simple and plug it straight into either my laptop or desktop PC to eliminate that possibility!
  1. 02 problems
    By lgarner in forum Petrol / Gas
    Last Post: April 4th, 2010, 10:04 PM
  2. V2 problems :(
    By CDR in forum FlashScan V2
    Last Post: March 2nd, 2009, 05:56 AM
  3. 98 sd problems...still...
    By rubbersidedown in forum Gen III V8 Specific
    Last Post: February 7th, 2009, 07:18 PM
  4. Having some Problems with LM-1
    By mwalls54 in forum General
    Last Post: January 21st, 2006, 09:05 AM
