Results 1 to 6 of 6
Thread: wondering about my 02's log attached
    Lifetime Member Gregs's Avatar
    Sep 2008
    Default wondering about my 02's log attached
    I just wanted to get a second opinion on my bank 2 sensor. It doesn't switch back and forth it just stays right around 450 mv. At the same time my stft for bank 2 is pegged out at 99%. The thing that I don't get is why my bank 2 ltfts are perfect. What do you guys think?
    03 Silverado 5.3 ECSB 4x4 Z71
    Comp Cam 206/212 .515/.522 112 lSA, hardened rods with LS9 springs
    2010 Tahoe VVT AFM 5.3
    Stock for now
    Sep 2008
    just giving this a little bump, but since my first post i have swapped out o2 sensors a few times with other ones i have laying around and i still have the same problem. Its as if the sensor just isn't switching back and forth no matter what o2 sensor i have in there. anyone have any theories?
    Stock for now
    Jul 2008
    Gregs:
    Thought I would help your bump...
    Are you logging both O2's on the same bank? I usually log just the front O2's of each bank.
    Our set-up is probably quite different, but was just trying to understand what you were doing..
    You might be logging the wrong pids...
    replace O2Sxx with SHRTFT1/2.
    Aug 2010
    Played log in "data" format, couldn't see it well enough in the "dashboard B" format ... no O2 voltage from either bank, no short term fuel trim from either bank.
    Regards,
    Taz
    Sep 2008
    problem solved. Looks like i mixed around a few pids when i went to bbl. thanks for your help guys!
    Stock for now
  1. Where is all my timing going??? Log attached
    By exploder in forum General (Petrol, Gas, Ethanol)
    Last Post: May 24th, 2010, 05:55 AM
  2. Wondering about a table
    By azzhauler in forum Gen III V8 Specific
    Last Post: July 12th, 2009, 11:01 AM
  3. o2 sensor switching question (log attached)
    By brentg454 in forum Gen III V8 Specific
    Last Post: April 6th, 2007, 01:19 PM
  4. Can't increase timing while brake stalling (tune and log attached)
    By thunder550 in forum Gen III V8 Specific
    Last Post: January 18th, 2007, 04:44 AM
