Results 1 to 2 of 2
Thread: Truck idles like crap/dies when fuel level is less than 1/4 tank, fuel pump?
    Jan 2007
    Default Truck idles like crap/dies when fuel level is less than 1/4 tank, fuel pump?
    I have had this annoying problem for about a year now. When ever the fuel level gets below 1/4 tank the truck starts having some idle issues... It will surge and sometimes die... But it only does it when it is below a 1/4 tank... I am starting to think it is my fuel pump. Another reason i think my fuel pump may be weak, is my VE values in the 95-100kpa range are above 110%, i think i peaks at 115%... I have 31# 8.1L injectors and my IDC is about 74%....
    I only have issues at idle when it is below 1/4 tank, once off idle it is the exact same.... My LTFTs stay about the same the no matter what fuel level i am at... The only other thing i can think of is there might be some emissions test that occurs below 1/4 tank... I have put a mechanical fuel pressure gauge on it before, the fuel pressure was good, except i had about 4-5 PSI drop at WOT...
    My truck is a 4.8 with the following mods if it makes a difference.
    TBSS intake, PRC stage 2.5 heads, FTI 214/220 .600/.597 108+2, 3600ish, EFILive, Efans, Airaid CAI, UD Pulley, AEM Lts, Magnaflow, DMH e-cutout, 4.10s, TrueTrac, Transgo HD2, Servos
    I have tuned it with my LC1 wideband...
    Any ideas?
    It might have to do with the EVAP (fuel tank pressure) test, but I thought that it was run when tank was between 1/4 and 3/4, and while driving...
    Remove the purge solenoid's tube from the front of the manifold and cap the port on the manifold, if this makes a difference then the problem is in the EVAP system.
  1. E38 fuel level sensor calibration
    By harascho in forum E37, E38 & E67 PFI ECM's
    Last Post: November 29th, 2009, 03:39 PM
  2. changed fuel tank size
    By evilspyder66 in forum General (Diesel)
    Last Post: March 29th, 2009, 01:33 PM
  3. Fuel Level Sensor Primary F0101
    By Schweinmesser in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: February 10th, 2009, 05:01 AM
  4. Fuel Tank Parameters
    Last Post: April 7th, 2007, 11:57 PM
  5. Adjusting fuel tank measurements?
    By Garry in forum General (Petrol, Gas, Ethanol)
    Last Post: July 20th, 2006, 09:53 PM
