I have had this annoying problem for about a year now. When ever the fuel level gets below 1/4 tank the truck starts having some idle issues... It will surge and sometimes die... But it only does it when it is below a 1/4 tank... I am starting to think it is my fuel pump. Another reason i think my fuel pump may be weak, is my VE values in the 95-100kpa range are above 110%, i think i peaks at 115%... I have 31# 8.1L injectors and my IDC is about 74%....
I only have issues at idle when it is below 1/4 tank, once off idle it is the exact same.... My LTFTs stay about the same the no matter what fuel level i am at... The only other thing i can think of is there might be some emissions test that occurs below 1/4 tank... I have put a mechanical fuel pressure gauge on it before, the fuel pressure was good, except i had about 4-5 PSI drop at WOT...
My truck is a 4.8 with the following mods if it makes a difference.
TBSS intake, PRC stage 2.5 heads, FTI 214/220 .600/.597 108+2, 3600ish, EFILive, Efans, Airaid CAI, UD Pulley, AEM Lts, Magnaflow, DMH e-cutout, 4.10s, TrueTrac, Transgo HD2, Servos
I have tuned it with my LC1 wideband...
Any ideas?
