Results 1 to 2 of 2
Thread: no allison 6 speed
    Jul 2006
    Default no allison 6 speed
    I updated to verson 8.1.2 Build 115 and lost the ability to log my 6 speeed Allison. when i go into the F5: Black box Settings and try to select it as the Module and it is not there. the 5 speed is but not the 6 speed.
    Apr 2008
    Had the same issue too. Go to the main part of the forum at the top on Software installation. Read the sticky on the V8 pass through and install that update and firmware. I believe that was what I used to get it back.
    Brian
    2007.5 GMT-900 Chevrolet Silverado 2500HD CC/LB LTZ 4x4 Summit White.
    With the LMM Duramax 365hp/660tq, MW7 Allison 1000 6-speed
    EFILive LMM DSP5 Settings, 500HP, 450HP, 400HP,Tow with Turbine Brake, and Stock HP.
    UA Steamfitter, Local 136 Evansville, IN - Remember if you want to play you got to pay.
  1. 6 Speed Allison TCM's
    By Cougar281 in forum Allison 5 & 6 Speed
    Last Post: February 15th, 2011, 09:23 AM
  2. Allison 6-Speed PIDs
    By 8100 Power in forum Diesel
    Last Post: September 29th, 2008, 01:58 PM
  3. Allison 6 speed
    By lucky1 in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: December 10th, 2007, 11:50 AM
  4. 6 speed Allison
    By Boost in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: June 21st, 2007, 11:03 AM
