Results 1 to 3 of 3
Thread: E67 After Run Fan Settings?
    Aug 2010
    Default E67 After Run Fan Settings?
    I have been messing with the after run fan settings trying to get them to run after the car is shut off. This car has an electric water pump, turbo, headers and a lot of under hood heat, so I want the fans and water pump (is activated by the fans) to run for a bit when the car is shut off. I can't seem to get it to work. I have set the parameters to:
    buschemi vve_0015.tunClick image for larger version.
    does the after run have limits like the run fans do (192 deg)? Any help would be great.
    Aug 2010
    Hello MattS,
    You’re working on a ’07 Monte Carlo SS with an LS4 5.3 L and a 4T65E ?
    Regarding fan settings …
    G0901
    • controls fans during normal engine operation (engine running)
    • based on ECT
    G0902
    • based on ACP (air conditioner pressure)
    G0922 – G0926
    • are “after run” (engine not running) parameters
    You should be able to set these parameters to suit your needs, without effecting G0901 or G0902 function. That is, set the temps for high (G0922 & G0923) and low (G0924 & G0925) to what you require. Set maximum run time (G0926) to have the effect you’re after, keeping in mind reasonable reserve battery power.
    Regards,
    Taz
    Aug 2010
    Ya, I got the settings, they just don't seem to work no matter were I set the upper or lower temp settings. I am working on a monte carlo, kind of a 5.3, not much GM left in the engine. ECU is stock except for a 2.5 bar map and 4" maf and the calibraiton. The engine run fans work fine.
    Thanks for the help,
    MattS
  1. '08 TBSS E67 fan control?
    By JAY4SPEED in forum E37, E38 & E67 PFI ECM's
    Last Post: April 21st, 2011, 04:08 PM
  2. 160 Deg. Stat Fan Settings?
    By n8dogg in forum Gen III V8 Specific
    Last Post: September 14th, 2010, 05:24 AM
  3. What is fan after run mode ?
    By 2010 Bumblebee in forum General (Petrol, Gas, Ethanol)
    Last Post: May 5th, 2010, 04:07 AM
  4. Fan settings E38
    By eboggs_jkvl in forum E37, E38 & E67 PFI ECM's
    Last Post: August 14th, 2008, 11:15 PM
  5. Electric Fan Settings
    By mtnman in forum General (Petrol, Gas, Ethanol)
    Last Post: January 1st, 2006, 08:24 AM
