Page 3 of 3 FirstFirst 123
Results 21 to 27 of 27
Thread: GMPP LS3 with GMPP Controller Tacho control
  1. #21
    Aug 2010
    The longer the thread gets, the more we go in circles !
    Current ECM & tune - can only copy segment from a System folder from another tune of the same OS - not very probable as this is a proprietary GMPP OS (non-production). Means wiring a resistor / tach adapter.
    Current ECM - reflashing with production OS - as you know, E38 & E67 don't actually get a full reflash - require an appropriate "base tune" to already be in the ECM - not sure how this would workout with GMPP tune. May have to have a "base tune" loaded in the ECM via a Tech 2.
    The last option - different E67 with appropriate base already installed (from auto recycler) - then tune from there.
    Those are all of the options I can think of - personally, I would just wire in the Tach - pick the "best" place (away from known sources of moisture) solder everything, and seal it in 2 overlapping layers of shrink tubing.
    Regards,
    Taz
  2. #22
    May 2009
    Thanks Taz!
    Completely clear.
  3. #23
    Taz, you can full flash E38/E67s as long as you are careful and know that the new OS will not brick the ECM. For example, I bought a set of cores off a friend with an 07 TBSS OS and full flashed my 08 TBSS OS. Only issue was the VIN, I had to manually reprogram it. For a GMPP OS to a stock OS, Im not sure which ones work as I have not tried it before. E67s dont seem to be as picky as E38s from what Ive seen, just dont flash a 10+ OS into an 06-08 E67.
  4. #24
    Aug 2010
    Yes, you can use the full flash option on E38 / E67 ... but my understanding is that doesn't copy over everything - like a full flash on an LS1-B style PCM. If the original (donor) E38 / E67 was from a V6 (etc.), that original "platform" would remain resident in the ECM, even after a full flash. Just need to confirm the "base tune" is compatible with the eventual "end product".
    Turbocamaro - I should have used "lol" instead of "!" in the above thread #21 - was laughing, not frustrated. Hope I didn't misconvey that.
    Regards,
    Taz
  5. #25
    May 2009
    No worries,TAZ. No conveyance taken.
    I was thinking there would have already been some experience with the crate motors and controllers GM has released. It seems as though it isn't so therefore we have some learning to do. I think that it will probably be simpler on future builds to not use the GM Performance controllers rather use a custom harness and factory type controller.
  6. #26
    Aug 2010
    Questions like yours seem common with the GMPP systems ... I've never used one ... but it appears GM should provide more "up front" information, or more detailed instructions. I'm guessing GM's intent was to allow the end user to setup the system without the need for any programming - hence the analogue gauge outputs. For an experienced person or professional shop, it limits certain tuning options.
    Probably half of the transplants I've done have used a re-worked OEM harness (most cost effective option as the customer often gets the harness with the engine). Just takes a little time to make it look nice !
    Regards,
    Taz
  7. #27
    Oct 2010
    Quote Originally Posted by Taz View Post
    Regards,
    Taz
    It seems crazy to sell a performance motor/ controlling system and not have a "ready to go" tach setup.. Or like you said "information disclosed that your tach is going to take more time than your whole install" lol.
  1. GMPP E67 and Cruise Control
    By 95wagon in forum E37, E38 & E67 PFI ECM's
    Last Post: September 29th, 2010, 04:39 PM
  2. E67 GMPP dies on decel
    By pandreas in forum E37, E38 & E67 PFI ECM's
    Last Post: February 25th, 2010, 12:30 AM
  3. E67 GMPP controller checksum error
    By xtreme in forum E37, E38 & E67 PFI ECM's
    Last Post: November 10th, 2009, 03:50 PM
  4. GMPP E67 missing pids??
    By Redline Motorsports in forum E37, E38 & E67 PFI ECM's
    Last Post: May 24th, 2008, 08:44 PM
  5. GMPP Gen-IV controller kit
    By PSWired in forum Gen IV V8 Specific
    Last Post: April 18th, 2008, 01:50 PM
