ok i have a 5.3 turbo'd we are trying to get the car to run in closed loop and having no luck with the o2 sensors working. i have them wired correctly on power one ground for the heater and a high and low side. i have checked the continuity of the wires for the high and low side and every thing checks out. i even replaced the o2 sensor no luck
this is a 411 pcm with a custom os. possibly i am logging the wrong pid's?
i have the factory narrow band hooked into rear bank2 sensor 2 and the lc1 narrow band side hooked in to bank1 sensor 1. i was moving them around the pins just to check other places to get readings.
here is a log file..
Log_0014.efi
any idea's on what i am doing wrong here would help.
