Results 1 to 7 of 7
Thread: Question: Proper way to test CP3???
    Sep 2010
    Default Question: Proper way to test CP3???
    What is the proper way to test the CP3 on a 03 GMC Duramax with EFILive?
    Which PID's should be looked at?
    Attached (i hope) is a log.
    Not sure I loooked at the rigth stuff.
    Please look at it and let me know.
    TIA
    Junior Member mijdirtyjeep's Avatar
    Mar 2009
    I would say it is not looking good for your CP3 "desired 160mpa, and you are only getting 90.4mpa".
    Also looks like your FPR is on the way out as well, is your truck surging at idle? How many miles on the injectors? I did not see the balance rates on them!
    The only other test would be a return rate test, to rule out bad injectors returning too much fuel.
    PS: I just replaced one in a truck though that had about the same Desired vs Actual Mpa's and it solved the problem.
    Jim
    2003 Duramax/Allison
    Modded Turbo Mouth Piece
    Modded Factory Air Box
    285/65R18 Hankooks on 18" Predators
    4" Magnaflow turbo back
    PPE Boost valve
    EFI V2 with Dsp2 switch
    MAG-HYTEC rear diff. cover
    Sep 2010
    119k miles on injectors
    Injectors are within spec at idle truck warm in park.
    #4 and 5 are border line but under 4.
    Injectors while in Drive with brake pedal pressed are in spec except # 4 and 5 are at 6+ at times but not constant. They bounce in and out.
    I get white smoke here and there also.
    No surging at idle or anywhere
    No lope
    Lines all seem to be kink free and none are collapsed
    Getting a P1093 code
    Code only started popping up after I installed a nicktane filter adaptor with a cat filter.
    Running a Hypertech 90hp tune
    It was suggested to me to do the shim kit for the FPR
    It was also suggested to me to do a lift pump
    I don’t want to waste $ on a lift pump if what I really need is a CP3
    Mar 2009
    With that many miles on your injectors, and from the looks of your balance rates. I would say your injectors are GONE. Injectors WILL cause a a low rail pressure code as well as a failing CP3, or a restricted fuel supply. You need to do an injector return rate test to verify this though.
    Sep 2010
    Logs
    Stock Tune
    Nicktane adaptor still but, now modded by me for more flow
    NO CEL as of yet
    Have not been able to drive the route that would always make the CEL come on
    Sep 2010
    Put on a stock fuel filter
    Still get P1093
    Then I shimmed the FPRV (PITA)
    It looks like it helped the balance rates for INJ #4 and 5 while in drive.
    Check the logs and let me know what you think.
    I think the CP3 needs to be changed.
    10.7.10 Stock.rar
    10.7.10 FPRV Shim logs.rar
    Mar 2009
    Until you do an injector return rate test there is no way to say with certainty that the CP3 is bad. And you have to remove some of the fuel lines to do one as it isn't an electrical test. Don't feel bad though, I'm in the same boat with injectors that are only 14 months old.
  1. LB7 to LBZ CP3 swap tune adjust
    By jstrese in forum Duramax LB7
    Last Post: September 18th, 2011, 11:19 AM
  2. Proper Way to Dyno
    By LBZoom in forum General (Diesel)
    Last Post: June 18th, 2010, 01:43 PM
  3. CP3 test
    By ARZ in forum Duramax LB7
    Last Post: February 17th, 2010, 04:31 PM
  4. Proper way to raise part throttle shift points
    By Redline Motorsports in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: September 16th, 2006, 01:44 PM
  5. QUESTION ON CYL BALANCE TEST
    By tuff in forum General (Petrol, Gas, Ethanol)
    Last Post: July 6th, 2005, 02:24 PM
