Results 1 to 8 of 8
Thread: CASE Learn
    Mar 2009
    Default CASE Learn
    Just wondering how to do this? click case learn button in efi live then rev to what? 2500? then it misfires or something like that and your ment to turn car off for 15 seconds
    Aug 2010
    Scan Tool user manual - read pages 152 & 153 for instructions on Crank Position Sensor Relearn
    Regards,
    Taz
    Yes, bring rpm above 4000 within 10 seconds, engine will stumble for a moment, allow to spin down to idle, turn off for 15 seconds.
    Manual indicates conditions that must be met as Taz indicated above.
    Mar 2009
    I never got a user manual with mine i don't think nothing 150 pages?? where is that from?
    Lifetime Member Gregs's Avatar
    Sep 2008
    open up the scan tool click on help, then click on help contents. it opens a pdf manual
    03 Silverado 5.3 ECSB 4x4 Z71
    Comp Cam 206/212 .515/.522 112 lSA, hardened rods with LS9 springs
    2010 Tahoe VVT AFM 5.3
    Stock for now
    Quote Originally Posted by nathans1987 View Post
    The user manual is included as a .pdf file with the V7 download, there has never been a printed user manual (at least in the last 4.5 years Ive been using EFILive).
    Aug 2010
    Manuals and Tutorials were probably downloaded to C:\Program Files\EFILive\V7.5\Doc\Tutorials - there should be a about a dozen *.pdf files.
    When I first started with EFILive I printed these out, and organized them in a binder - it's about 6 inches thick !! I still use it frequently ... also worthwhile to invest the time in reading them all ... just to fully understand the scope of the software.
    Regards,
    Taz
    The scantool and tunetool user manuals are must-reads if you want to be able to use the tools to their best ability.
    The tutorials are very good reads because they indicate certain table relationships/interactions that a person might have not pick up on in the forum.
  1. CASE Learn not working?
    By DPS in forum General
    Last Post: June 11th, 2010, 04:49 AM
  2. Where is CASE learn stored?
    By N0DIH in forum RoadRunner Real-Time PCM Emulator
    Last Post: October 17th, 2009, 04:06 AM
  3. CASE Learn on a RR?
    Last Post: August 1st, 2009, 01:37 AM
  4. EFILive v.7.5.5.xx Cannot CASE Learn
    By Denaliano in forum Gen III V8 Specific
    Last Post: April 18th, 2009, 07:28 AM
  5. Where to LEARN
    By board350 in forum General (Diesel)
    Last Post: April 26th, 2008, 08:22 AM
