If I want to change from the stock 26 lb injectors to the stock 28 lbs injectors do I just copy all the tables from the tune from the year with the larger injectors?
This is for my 99 formula.
I am also in the process of acquiring/installing the fuel pressure sensor so I can log the actual pressure to fine tune the settings.
Thanks in advance.
Brad
