OK, on the tach:
Cranking
8
8
Reads pretty accurate at 750-850 idle. 3 was 2400 at idle. 8 is pretty much spot on.
but getting this error:
Error code: ERR_IGNORED/4
No response from vehicle.
OK, on the tach:
Cranking
8
8
Glad to hear you got it working ... ignore my inquiry in the other thread - had been curious as to which values had ultimately worked ...
Regards,
Taz
Any ideas on this new error code?
The ECM does not need the value to be 6 to work correctly does it? I put it back to 6, still getting error code.
G1202 & G1203 are tach output from ECM - shouldn't cause an issue - as these are output, not input values. If I recall, the original values were 2, then we tried 6 (used by LS1-B PCM) ... then fine tuned to 8 - which corrected Tach reading.
Not sure what you mean by an error code ... never tuned an E38 ... DTC code ?? Or error between modules ?? Original Tach output I believe was serial data - probably to the IPC ...
Regards,
Taz
Thanks.
I thought maybe the ecm needed this tach data to calibrate the program but if its just output, that is cool.
Scan tune says this whe I try to read now:
Its probably unrelated.
OK ... error from Scan Tool, not E38 ... now I understand ... what were you trying to do with the Scan Tool when you received that error ?
Regards,
Taz
Just trying to read the car while its running. It wont read it now.
Read it while running? Or do you mean scan? You cannot read or flash while the engine is running, but scanning/logging is done with the engine on. Latest software, etc?
+1 reading the PCM must be done with engine not running.
Yes its all updated as of last week, when it was reading.
By the way I changed tach to "9"s from "8"s and its more accurate.
All that said, I can reflash but it wont log or scan anymore. What is up? I did have the laptop plugged in. Please tell me I did not brick the controller.
Bug report
Bug report 10 2 2010.txt
Last edited by 68problemchild; October 2nd, 2010 at 04:39 AM. Reason: added bug report
