Page 1 of 4 123 ... LastLast
Results 1 to 10 of 35
Thread: Tuning a 4L60E with Transgo HD Shift Kit
    Senior Member blsnelling's Avatar
    Sep 2010
    Default Tuning a 4L60E with Transgo HD Shift Kit
    I'm looking for advise on tuning the trans in my truck. I just put a 6.0 in front of it, hoping for 400 RWHP. I've had a Transgo HD shift kit in it for some time with aluminum accumulator pistons, and 4th gear hold servo. I had a 'vette 2-4 servo in it before, but didn't like the harsh 1-2 shift. That was before the stall converter. Probably wouldn't be an issue with my PT3200.
    I currently have all shift times set to 0.00. I understand that's what I want since I have the shift kit in it.
    What about Trans Pressures? I currently have all stock Performance pressures in the Base Pressure Shift tables, for both Normal and Performance columns. All other pressure tables are stock.
    Of particular concern, I'm getting an occasional 2-3 flare at part throttle. I never had this happen before the new converter, engine, and tune. Any ideas there?
    Aug 2010
    Try reading through the threads below ... I used the transmission tuning tutorial by Joecar when I was trying to learn "how things worked" ... it's a good read.
    http://forum.efilive.com/showthread.php?t=1723
    http://forum.efilive.com/showthread.php?t=5876
    http://forum.efilive.com/showthread.php?t=10773
    There are more tutorials in the "General information" portion of the Forum under the "Tutorials" category. Joecar has been busy sourcing applicable threads, and grouping these in a logical manner.
    Couple of more threads regarding trans mods and the TransGo HD2 kit ...
    http://forum.efilive.com/showthread....shift-firmness
    http://forum.efilive.com/showthread....during-upshift
    Regards,
    Taz
    Hi blsnelling,
    Welcome to the forum
    If your PT 2->3 shift flares, then see if this makes any difference:
    - increase the 2->3 pressure table;
    - set the 2->3 shift time table to 0.2 seconds all across (yes, this is counter-intuitive );
    Post your .tun file.
    Sep 2010
    Hi blsnelling,
    I did bump the 2-3 pressures +6. My shift times are all at 0.0. You're saying to up them to 0.2? Yes, that's counter-intuitive How would that work? The above post may change your response though.
    Here's ,my tun file. My Modified_02.tun
    Quote Originally Posted by blsnelling View Post
    Try the attached file.
    Sep 2010
    Thanks. I'll check that out when I get back to my laptop later this evening.
    Sep 2010
    What's your logic behind making the 3-2 and 4-3 Throttle Kickdowns 100% across the board? Also, how can a slower shift time of 0.2 help the 2-3 shift?
    The throttle kickdown tables can interfere with the PT up/down shift tables... by setting them to 100% allows PT shifts to be controlled by the PT shift tables only rather than switching between PT shift tables and throttle kickdown tables.
    The hydraulic hardware may be taking its time perhaps (for some reason or other); when the PCM has to meet 0.2 s it will successively increase the pressure rate until the time is met; try it to see if it makes any difference.
    Sep 2010
    Thanks Taz.
    Sep 2010
    I think I narrowed this occurance down. If left in D, it shifts properly. If I start off with it pulled down in 1st, to keep it from shifting as I feather the thottle to prevent too much wheel spin, and then move it to 3rd, the 1-2 is great, but 2-3 flares BADLY. I hit 6700 RPMs before I let off. I then made two more runs with it in D, and it shifted correctly from 2-3 both times, no flare at all. What would cause that?
    This has probably existed before now, but I've never had a problem with wheel spin, so never had to pull it into 1st to keep it from shifting as I feathered the throttle
  1. 4L60 and shift kit
    By SRT10KLLR in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: February 21st, 2013, 12:13 AM
  2. Built 4l60 w/Transgo shift firmness
    By InTruckDesign in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: September 30th, 2010, 01:33 PM
  3. 4L60E shift points
    By maudyZ28 in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: April 28th, 2010, 02:37 PM
  4. 4l60e wont shift
    By chris98z71 in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: January 26th, 2009, 07:26 AM
  5. Disable adaptive shift learning after Shift Kit Install
    By BlackGMC in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: January 24th, 2008, 05:49 AM
