Results 1 to 7 of 7
Thread: Hanging idle.....what do you think?
    May 2009
    Default Hanging idle.....what do you think?
    90mm now.tun
    Hope I attached my tune right? This is an LS1 transplant into a Nova, stock longblock, FAST 90/90 and the big Trex cam. Car idles good but when revved up off of idle, it hangs for maybe 6 seconds before it drops to an idle again. When its cold and I start it....it idles high for 10 seconds, flares up the drops down to a normal idle. Can someone look at my tune and give me some ideas? Thanks.
    Jul 2008
    Quote Originally Posted by Slow73 View Post
    90mm now.tun
    On your 1st example (Hanging Idle), are you talking about Idle Characteristics when the VSS is zero? What happens if you are going 10 mph and just put the car in Neutral..do the Rpm's hang or do they drop?
    On your cold Idle problem..what are the ECT's when this occurs.
    As always it is trying to figure out what Airflow Table is Commanding at the time..
    Edit..I wonder if Table B4314 is the culprit. That value would mean the Throttle Cracker would never delay?
    Last edited by WeathermanShawn; October 2nd, 2010 at 09:28 AM. Reason: Additional Information..
    May 2009
    As for vehicle speed, it a ls1 swap with a turbo 350 trans, no VSS. As with all of my other car with no vss, its tricky coming to a stop but driving around and letting off the gas has always been fine. As for ect when this happens, dosent matter if it hot or cold, always flares up then settles down to idle. The hanging idle is bugging me....no matter what my ECT is, when the car is in park and you give it some throttle, even just a fast hit of the pedal, it revs and takes 8-10 seconds to idle again. Is there something I should try with B4314? I appreciate the help.
    May 2009
    Wow....b4314 looks way outta whack compared to my stock file......I cant even explain how that happened! Do you think I should try my stock values or something different?
    Jul 2008
    I have seen B4314 values like that in other LS1 years, but try using stock values.
    Hanging Idle problems may be in the numerous Airflow Decay Parameters, so they can be tricky to track down. Looks like you have made changes in some of the Start-Up Airflow Correction and Decay? I try to leave a lot of those stock..you normally don't have to mess with them.
    The only other thing I was curious about is B4501 & B4502. That effectively disables the Idle Learning Parameters. These are the Airflow parameters needed for the IAC to 'learn'. They are not related to LTFT, STFT in their function, so Open-Loop Tuning does not really require you to disable them.
    Looks like you have reviewed the Idle Tips & Tricks, but any Airflow Table you can leave stock, makes tracking down these 'Hanging Idle' problems easier..http://forum.efilive.com/showthread....ips-amp-Tricks
    Good luck..
    May 2009
    Ill try and return B4501 and 02 to my stock parameters. I can also try and return the start up and decay to stock too. I made a little progress, I removed 10% from my Desired Idle Airflow and it really helped my hanging idle. In park, im able to give it some gas and the rpm dosent hang anywhere near what it did. It actually dips a tiny bit below my desired idle rpm and catches itself then idles again. I do still have the flare up when cold or hot. Say for example, I drive the car for 30 minutes, shut it off.....restart it again after sitting 1 minute......it will idle high for a few seconds.....flare up say to 16700 rpm, the drop and idle normal.......any opinions on startup besides trying stock values?
    Jul 2008
    Hot re-starts are always a problem. I usually relate that to fueling more than IAC. On restarts my IAT usually has shot up 30-40F (heat-soak) and runs choppy and lean for 10-15 seconds. Most of the Start-Up Airflows (B4304) do not add any additional airflow above 80C. If you have a lot of air in that Table, that may be causing your problem.
    The only reason I ever advise stock is just to slowly eliminate every Table that might be causing a problem. You could always log every IDLE/IAC Airflow Pid..then using the Tune Tool track what Table the airflow is coming from.
    But, that takes a lot of work..hence I go back stock first and work my way from there.
    Let us know what you come up with..
  1. Hanging idle
    By bobbycollier in forum General (Petrol, Gas, Ethanol)
    Last Post: April 13th, 2009, 04:24 AM
  2. Idle "hanging"
    By 12sec.5.3 in forum Gen III V8 Specific
    Last Post: February 1st, 2009, 10:53 AM
  3. EFILIVE _TUNE.EXE HANGING...on startup
    By TFZ_Z06 in forum General
    Last Post: September 21st, 2008, 10:16 AM
  4. Newb help w/ hanging idle & logging
    By LS1-450 in forum Gen III V8 Specific
    Last Post: April 19th, 2008, 11:15 PM
  5. Hanging idle on stock LS7
    By Stoichiometric in forum Gen IV V8 Specific
    Last Post: March 21st, 2008, 08:37 PM
