Page 1 of 5 123 ... LastLast
Results 1 to 10 of 42
Thread: Calc. VE Tuning - Newbie getting started
    Senior Member blsnelling's Avatar
    Sep 2010
    Default Calc. VE Tuning - Newbie getting started
    I just got my v2 and have spent the afternoon figuring out how to do a Calc. VE tune. I've got the calc pids, maps, filters, etc all setup. I don't yet have a wideband O2. I don't see where it's used in the calculations/corrections. Why is it shown as required in the Introduction? Which PID shows the existing O2 output?
    Am I correct that this is the first thing I want to do in my tune? I'm starting with a mail order tune that seems to be running well. I just want to dial it in as close as I can, and verify that it's all correct.
    Jul 2008
    Hi there.
    You can do a lot of the CALC.VE Table Tutorial just using your factory Narrow-Bands (O2's). Where you must utilize a wideband is when you start going into PE Mode (>50% Throttle, etc).
    When in closed-loop you utilize the LTFTBEN portion of the calculation. PE Mode is open-loop. The formula still calculates your VE in PE Mode by utilizing the MAF Frequency, IAT, ECT, etc. The wideband is to get your actual fueling correct.
    Remember, both MAF & VE are Airflow Tables. Fueling needs need to be addressed with a wideband.
    If you intend to stay Closed-Loop and keep your MAF enabled, CALC.VE Table will allow you to maximize airflow, fueling and spark loads..both at Idle and WOT.
    Hope that helps..
    Sep 2010
    I'm still not clear, lol. Remember, I'm a newbie at this.
    I will be keeping the MAF. Bottom line, how do I tune the MAF and VE tables without a wideband O2? It appears to me that the wideband O2 is only used to ensure the results are correct. It doesn't appear to be used in the calculations at all.
    On another note, I'm getting all 0.00 values in the VE_Table map, and 0.0 and an occasional 0.1 in the LTFTBEN map. What would cause this? I thought maybe I had some metric/imperial values mismatched, but they are not.
    Sep 2010
    Here are my pid files. calc_pids.txt, Calc.VE.pid
    Rename these to .map files. CALC.LTFTBEN.txt, CALC.VE_Table.txt
    Lifetime Member Boost's Avatar
    Dec 2006
    On this topic, I am trying to add the 3 required extra PIDs and when I open the scan tool it gives an error message that it can't find them and closes.
    "Hint, Additional information about use and creation of calculated
    PID’s can be found in the EFILive Scan Tool help manual."
    (Where?)
    "format of this file is explained in the file itself. Use a text file editor to load the file and read the inline ments." (all I found there)
    "Error code: ERR_CONFIG/92
    C:\Users\User\Documents\EFILive\V7.5\User Configuration\calc_pids.txt(54): Units /(4.800)*{SAE.RPM}*{SAE.MAP.kPa})*{CALC.LTFTBEN}" not found. . "
    8.7 @ 84 (1/8 mile) bolt-ons
    Sep 2010
    You can use my calc_pids file above.
    I'm wondering if I'm getting all 0.00 in my VE_Talbe map because it can't find the displacement. I just replaced that with 5.964, and will see what happens.
    Sep 2010
    I see where PE Mode is enabled anywhere from 60-75% TPS in B3618. I've yet to see a tutorial on tuning PE mode. I'm just not putting the pieces together here. It seems as there's no tutorial that goes step by step through tuning a vehicle. I'm only finding pieces, and haven't got the whole process figured out.
    Jul 2008
    Quote Originally Posted by blsnelling View Post
    It is O.K. We have all been 'newbies', or at newbies in some area of tuning..
    You are utilizing the narrowbands for most of the calculations. In math that is called a 'known' factor. Though you don't see the ~14.7 AFR being calculated, it is indeed being used. You are calculating a correction to it. The wideband AFR must match up with each of the MAF Frequencies when you go heavy on the throttle. If you are too lean or rich the match-up between the MAF and your AFR absolutely effects the VE calculation!
    The best advice I can give you at this time is just take it slowly. The Scan & Tool software along with BBL take some time to set-up. I guarantee you if you utilize the PIDS as exactly described in the Tutorial and log..it will all make sense. Just staring at the formula will drive you nuts. But, again the AFR is being utilized at every point in the calculation whether by the narrowband stoich value or by wideband.
    I am not sure on your VE values. If you have something to post up it might make it easier to figure out..
    Jul 2008
    Quote Originally Posted by Boost View Post
    (Where?)
    Boost, I agree the write-up in the Scan Tool is not real easy for beginners to follow. In all honesty, I had Joecar greatly assist me on my first CALC PIDS..from there it made sense. Obviously, all the correct PIDS must be selected, units generally metric, displacement value must be accurate. Do you have DYNAIRTMP as a valid PID?
    Jul 2008
    BLS, best to not get too frustrated. Believe me I said the same thing you are saying when I first started. It took 2-3 months to write up the CALC.VE Table and that barely covers 1% of all tuning.
    There are a lot of differing vehicles, years, OS's..and not enough volunteers to write up areas of tuning. Check Joecar's signature..he has great links and summary notes.
  1. Need advise about Calc.VE Tuning
    By Ram Air IV in forum General (Petrol, Gas, Ethanol)
    Last Post: September 9th, 2010, 08:33 AM
  2. looking to get started tuning
    By smslyguy in forum Gen III V8 Specific
    Last Post: November 16th, 2008, 05:57 PM
  3. Need a little help gettin started on COS3 fine tuning. Please
    By nonnieselman in forum Custom Operating Systems
    Last Post: June 11th, 2007, 05:47 PM
  4. 2003 2500HD 6.0L - Started Tuning Yesterday Nice!
    By Black02SS in forum General (Petrol, Gas, Ethanol)
    Last Post: August 22nd, 2006, 10:45 AM
  5. Newbie - how to get started?
    By Garry in forum General (Petrol, Gas, Ethanol)
    Last Post: June 16th, 2006, 10:48 PM
