I have been searching and experimenting with my data logs in preperation of logging my wideband data this week. I started playng with my a/d inputs and got my NTK wide band working with some custom PIDs using the information here. I have read that the only sure way to defeat the maf for SD tuning is to unplug it. On my corvette I would have to rig up an IAT. With C2901 C2903 set to "0" when I log GM.MAF I get back only "0". With C2901, and C2903 reset to normal values I get data back during logging. Does this mean that I have effectively disabled the MAF, or just ignored the results?
When I log SAE.FUELSYS I see only "OL. Is there a way to verify that I am running SD and OL ? Also is there any PID that shows PE mode? When I graph PID SAE.FUELSYS all values show as #1.
Thank You,
Philip
