Page 1 of 5 123 ... LastLast
Results 1 to 10 of 48
Thread: E38 OS with T42 TCM
    Sep 2009
    Default E38 OS with T42 TCM
    I've been looking all over and can't seem to find anything on this. I'm currently working on a 2010 Escalade with an E38. Swapped the tranny out for a 4L60 with a T42 and was wondering if anyone has an OS that supports these two things together. Any help would be much appreciated.
    Feb 2006
    not sure if this will help. but it comes from a 12597121 ecu.
    Aug 2010
    A member recently completed a similar swap ... E38 controlled 2007 Escalade L92 6.2L with T42 controlled 4L70E ... thread below ... long read ... but lots of info ..
    http://forum.efilive.com/showthread....-help-a-newbie
    Regards,
    Taz
    Jul 2007
    All auto based VZ holden 6lt vehicles had this combo, E38 and T42 ( not HSV ). So it's certainly possible.
    Senior Member doubledip's Avatar
    May 2008
    Quote Originally Posted by swingtan View Post
    yes but will need to do something with the ISS as the E38 looks for it in the Holden OS's . a 4L60E in a Holden guise doesnt have it fitted and only certain 4L65E's had it fitted... so just beware
    E38's got to love them
    E40's hate 'em
    LS1's is there anything it wont work on
    Holden VE SSV - GEN46L
    www.ultimateconversionwiring.com.au
    www.dualflash.com.au
    Sep 2009
    The big thing is that the ECM is a 2010 and I cant find a calibration that is compatible with that. Anyone happen to have one?
    Feb 2006
    the export holdens to dubui also only had 4 speed auto's too.
    Hmm why bother swapping to a 4 speed?
    Regardless, you can try running an earlier T42 OS and see if it communicates to the ECM properly. The only issue running a Holden ECM OS is the likelihood of it not playing well with the BCM, cluster, etc in an Escalade. Is this swap in an actual Escalade or is it a swap?
    Sep 2009
    Its in an Escalade. The reason for the 4 speed swap is because the 6spds even built dont hold up that well to the power. This thing will be making around 850 at all 4 wheels
    Dec 2007
    The Silverado 4.8 Vortec has an A4. That would be the best chance. There is a guy on the Corvette forums that runs consistent low 10's in the brackets with an A6 and has run hi 9's.
    And a few other options here:
    http://archives.media.gm.com/us/powe...10truck_us.htm
    But the Silverado OS's would be the best chance to ensure the ECM and TCM are set with the necessary options to support the rest of the Silverado platform ECU's.
    The 4.8 has 24243357 in the T42 and 12636005 in the ECM. The ECM is the same OS for the A6 as the A4 so you really only need to do a cal flash to the existing E38 OS when you find the right ECM calibration for the A4.
  1. T42/E38 combo speedo issue
    By hymey in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: September 29th, 2010, 01:12 AM
  2. E67 ECM and T42 TCM Help Needed
    By finishline in forum E37, E38 & E67 PFI ECM's
    Last Post: February 7th, 2010, 07:04 AM
  3. E38 with T42 for 4L60E (no ISS)
    By gmh308 in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: July 24th, 2008, 01:19 PM
