Page 2 of 5 FirstFirst 1234 ... LastLast
Results 11 to 20 of 48
Thread: E38 OS with T42 TCM
  1. #11
    Aug 2010
    Attached is a 2010 T42 4L60E 4x4 from a pickup .... hopefully it helps.
    Regards,
    Taz
    Attachment 9158
  2. #12
    Lifetime Member 68problemchild's Avatar
    Mar 2010
    L92 with 4L70E
    I think its posted in my thread but if not, let me know and I can send you the tune.
  3. #13
    Dec 2007
    Quote Originally Posted by 68problemchild View Post
    L92 with 4L70E
    It's there...but dont try that '08 ECM file in a '10 controller. Not good!
    Taz's T42 file is a very close fit for the Silverado A4. Same segment numbers other than the cal segment itself so a very good chance.
  4. #14
    Sep 2009
    I really appreciate the help guys, ill let you know how it turns out.
    Anyone know where I can get the Silverado file to mate up with the T42 file from Taz?
    Any help is greatly appreciated
  5. #15
    Aug 2010
    Sorry misunderstood ... thought the 2010 T42 from the pickup would be compatible with the 2010 E38 from the Escalade ... have the pickup tune on file if it turns out you need it ... away until Friday afternoon ... could send it then.
    Hopefully the Escalade tune is compatible - would save you some work !
    Regards,
    Taz
  6. #16
    Sep 2009
    yea def, i will try it hopefully tomorrow and I'll let you know, thanks again for the help!!!
  7. #17
    Sep 2009
    No dice... i cant seem to get anything out of the ecm. Any chance i could get that file out of the truck that you have taz? Any help is much appreciated. Thanks!
  8. #18
    Dec 2007
    Quote Originally Posted by mbsurfersc View Post
    That's really odd. Post the tune from the ECM up and I will take a look at it.
  9. #19
    Sep 2009
    mod3.tun
    Couple of wierd things going on here.
    1. The ecm will not talk to the v2 through the obd port. When i put it on my bench harness though everything is seemless.
    2. Also when I turn the key over to try and start the truck, the dash and everything goes blank like it would normally be starting but It wont turn over. The vehicle does turn over however when you jump the relay.
    Not sure if the ECM not having a T42 friendly cal in it is causing the no start but the fact that it wont talk through the OBD port is really confusing.
  10. #20
    Dec 2007
    mod3.tun
    A few checkpoints:
    What OS patch/s do you have applied? Dont have a V2 with me at present so cant check.
    Is this the ECM that came in the truck? i.e. all VATS/security would be in line?
    Remembered a point on the T42. Normally they use a hardwired speedo/VSS line TCM > ECM. Not sure whether your platform with A4 does this, you would need to check the schematics. A6 generally transmits VSS via CAN but some trucks do use hardwire as well.
    When you wired in the TCM and trans wiring, what did you use for the pinout configuration?
    i.e. is CAN still passing through the TCM?
    FYI also - your tune is MY09. ECM should be service number 12625455.
  1. T42/E38 combo speedo issue
    By hymey in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: September 29th, 2010, 01:12 AM
  2. E67 ECM and T42 TCM Help Needed
    By finishline in forum E37, E38 & E67 PFI ECM's
    Last Post: February 7th, 2010, 07:04 AM
  3. E38 with T42 for 4L60E (no ISS)
    By gmh308 in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: July 24th, 2008, 01:19 PM
