Page 1 of 3 123 LastLast
Results 1 to 10 of 23
Thread: 2010 LMM VAT relearn
    Jan 2006
    Default 2010 LMM VAT relearn
    Using a used ECM, tested good, I flashed it with a stock 594 OS, changed VATs G0302 time to 10 seconds. Installed in vehicle, batteries charged, but the security light is not going out in 10 seconds.
    Any thoughts on what is happening?
    Custom Tuning Services
    Jan 2006
    update: while I programmed 10 seconds, the light goes out after exactly 10 minutes. 3x and still not turning over. Does have fuel injector codes, if that means anything. Will not programming injector rates cause a no-start?
    Junior Member jpgmtech's Avatar
    Mar 2007
    Fuel injector flow-rate DTC's shouldn't cause a no-crank. Any VTD codes?
    Jan 2006
    Probably, there is an anti-theft msg on the DIC.
    Jan 2006
    no security codes, but has "service anti
    theft system" on DIC
    It is really strange that the light goes out in 10 minutes, despite 10 sec programming, and at the end of what appears normal relearn, still no-crank.
    Feb 2007
    Why don't you just program the VIN into the ECM?
    Jan 2006
    IIRC, I did. Can you explain Josh?
    Feb 2007
    If you look at the drop down menus at the top of the tune tool, you will see one that says flash. Click on that and scroll down to the selection titled "PCM security...". A window should pop up. You will need to select your ECM from the drop down menu in there, and you will see several tabs at the top. One of them says "VIN/BCC". If you are hooked up to the truck, it should show your current VIN, and you can program a new VIN into the ECM if the correct VIN isn't already shown. If I'm not mistaken, the key cycle thing is just a longer, slower method of forcing the truck's VIN into a new ECM. The only problems I've heard of with VATS and new ECMs is no remote start. Without searching, I don't remember how to fix it, but I did it on my dad's LMM when I swapped ECMs on his truck.
    Jan 2006
    I do routinely change the VIN. 99% sure I did with this one.
    I am now wondering if somehow the counter got reset? If there is no other ideas, I may just have to retrieve it and try again. I am stumped for now.
    I didnt think you could actually change the VATS timer once it's programmed into the ECM (gas or diesel) for the first time? If Im wrong that would be sooo nice, I just havent tested it as I dont want to brick an ECM.
  1. Can not get V2 to read any TCM memory on 2010 LMM?
    By Mr.Blister007 in forum Allison 5 & 6 Speed
    Last Post: February 15th, 2011, 10:49 AM
  2. Replies: 3
    Last Post: August 27th, 2010, 03:24 AM
  3. 2010 LMM ECM tuning?
    By cumminsDK in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: March 4th, 2010, 06:26 PM
  4. Do I need to do a VAT Relink ???
    By Ninety8C5 in forum Gen III V8 Specific
    Last Post: May 27th, 2008, 02:44 AM
  5. VAT Relink
    By Biggsy in forum Gen III V8 Specific
    Last Post: October 10th, 2007, 09:40 PM
