Results 1 to 9 of 9
Thread: Fuel milage ??'s
    Oct 2010
    Default Fuel milage ??'s
    Has anyone had success increasing fuel milage with this product?
    May 2008
    There are several ways such as "Lean Cruise" DFCO settings, transmission, spark, and AFT tuning to increase mileage. My truck with modifications gets better fuel mileage than I did without them.
    E85 is NOT flex fuel.
    2003 Chevy S10 4.3L LU3 LS1B Auto
    48 LB injectors
    Race Proven Motors 2114 intake
    T70 turbo.
    Aug 2010
    Have look at the information in the "Tuning for Economy" and "Cax File" Forums ... several approachs to improve fuel economy ... magnitude of improvement depends on the vehicle and its intended use ...
    Regards,
    Taz
    Jan 2006
    Quote Originally Posted by Troop View Post
    That is a very general question as EFI Live is only as good as the person using it. If your asking can making the correct changes with EFI Live increase my fuel mileage the answer is yes.
    99 Z28 Camaro|LS1 Heads & cam Tuned by LSX Power Tuning
    2003 CC Duramax Dually|19.5 w/245/70/19.5|Tuned by LSX Power Tuning|5in exhaust
    2009 G8 GT Vararam CAI|Tuned by LSX Power Tuning|GXP Mufflers|Custom System
    2006 CTS-V K&N CAI|OBX Headers|Cammed LS3|Tuned by LSX Power Tuning|
    Oct 2010
    Ok sounds good, what about an '03 6.0 L chevy in a 3/4 ton 4 wheel dr pickup? There must be a lot of variables, as I am very ignorant with this product, but what type of increase(mpg) could be expected without loss of power?
    May 2008
    You can gain mileage and power if tuning is done correctly. With just tuning alone, I went from about 22 to 24 mpg on my truck.
    48 LB injectors
    T70 turbo.
    Troop, just clarifying, EFILive isnt something you just plug n play, you have to spend lots of time learning HOW to tune your truck yourself. If you just want mileage and dont want to spend time learning how to do it, then maybe buying a tune from a vendor is a better option. Not trying to scare you off if you want to learn, but from your posts in here Im getting the vibe you think that you just plug EFILive into your truck and BAM, instant mileage improvement. Not the case at all, EFILive is simply a tool and not an end result.
    2013 Sonic RS Manual - 1.4L I4T E78, starting the mods
    Oct 2010
    Thankyou, I appriciate the feedback. I already have a hypertech program installed and it does make a difference in power but not mpg. I understand that efi live is a much more complex system, I guess the question I should be asking is Will the efi live show me enough increase in mpg(over time) to justify the cost of the product?
    Jul 2008
    Not really.
    If you say currently get ~ 20 MPG, and at most gained 2 mpg through tuning (thats a lot)...with a 15 gallon tank that would be ~ 30 more miles per tank.
    That would be an extra 1.5 gallons saved. 1.5 gal X #3.00 gal = $4.50 per tank.
    If you fill up once a week, it would take ~ 130 weeks to make up $600...Close to 3 years.
    Somebody check my math, but in reality you could save more just by properly inflating your tires. While it is a source of pride to save gasoline, the real fun with this product is the joy of tuning.
    It is far superior to the product you mentioned, but I would not purchase the product solely for the purpose of picking up a few mpg.
    Thats my humble opinion..
  1. can someone help me get better milage?
    By smslyguy in forum Gen III V8 Specific
    Last Post: November 10th, 2009, 02:34 AM
  2. L.t.f.t closer to 0 affect gas milage?
    Last Post: September 1st, 2009, 09:19 AM
  3. 2005 impala 3800 milage
    By Slowrc in forum Tuning For Economy
    Last Post: August 25th, 2008, 05:41 AM
  4. fuel milage
    By tippyd in forum Gen III V8 Specific
    Last Post: February 23rd, 2008, 07:55 AM
  5. fuel milage
    By tippyd in forum Duramax LB7
    Last Post: February 22nd, 2008, 08:47 AM
