Results 1 to 5 of 5
Thread: Is NGK AFX compatible with V2?
    Oct 2010
    Default Is NGK AFX compatible with V2?
    This is my first post on this forum. I just purchased a V2 and now would like to monitor A/F ratios. The NGK AFX was recommended by a friend, but I want to make sure it will work well with the V2. Thanks for your help.
    Aug 2010
    Hello Truckmaster,
    Below is a recent thread from a member trying to get his NGK AFX setup. It's a long read ... but has a lot of detail and helpful material ...
    http://forum.efilive.com/showthread....hlight=NGK+AFX
    Regards,
    Taz
    Jul 2003
    Can you hook it up to a serial interface through the v2?
    Nov 2006
    It does not have serial connection, only analog.
    LC-1 WBO2
    Jul 2003
    Thank you!
  1. Wiring NGK Powerdex AFX to the V1 scan tool
    By voda1 in forum FlashScan V1
    Last Post: June 24th, 2010, 06:41 AM
  2. V7.5 Flashscan not compatible with V2?
    By TxChristopher in forum Duramax LLY
    Last Post: November 8th, 2008, 04:33 PM
  3. Error V2 not compatible?
    By 1SlowHoe in forum FlashScan V2
    Last Post: May 23rd, 2008, 02:40 AM
  4. V2 is not compatible w/ V7.4.2?
    By pkincy in forum General (Petrol, Gas, Ethanol)
    Last Post: May 14th, 2007, 05:02 PM
  5. Is Live compatible with Vista?
    By Redline Motorsports in forum General (Petrol, Gas, Ethanol)
    Last Post: February 22nd, 2007, 02:12 AM
