Results 1 to 6 of 6
Thread: turbo 400 conversion
    Jul 2010
    Default turbo 400 conversion
    hi there guys
    i got a 04 holden ute ls1 4l60e im installing a th400 just wondering what parameter and fault code issues im going to encounter and how can i tell the ecu its a manual ??? not sure of os number as my laptop is not with me
    You will need a manual transmission file.
    Sep 2010
    With this software are there no switches to the logic for automatic transmission or change switches for trans type?
    Paul Meister
    EFI Calibrator/Managing Member, Torq Speedlab, LLC
    Specializing in late model Ford, GM and Dodge EFI Calibrations
    SCT, EFI Live, HP Tuners, FAST, BS3 and much much more
    Jul 2010
    thanks guys ,,, ill get into it ,,, appreciated !!!!
    Jul 2010
    ok so say i obtain a manual file... how then can i put all my tables into it ,,, surely i dont have to sit there pencil and paper or copy and paste every single table and entry ??? also scaling injectors im looking to going to 60lbs from stock ,, how is this done ,,????
    cheers
    If the manual file has the same OS, then you can copy the trans segment into it.
  1. Closing turbo vanes for turbo braking?
    By Haulinbass02 in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: May 14th, 2009, 12:12 PM
  2. 98 camaro w/turbo 400
    Last Post: March 11th, 2007, 12:24 AM
  3. Tuning a 400 shot on a 408
    By minytrker in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: December 28th, 2006, 03:21 PM
  4. 98 vet os 200 to os 400 can it be done?
    By red12secz28 in forum General (Petrol, Gas, Ethanol)
    Last Post: June 19th, 2006, 01:29 PM
