Results 1 to 3 of 3
Thread: 4l60E Problems and Solutions
    May 2008
    Default 4l60E Problems and Solutions
    http://www.s10forum.com/forum/f13/4l...utions-297698/
    Common failures on 4L60E, symptom -> cause -> any possible repair:
    1. Slow, slipping or no reverse: “lo-reverse” clutches are worn out, fluid leak in the reverse apply circuit, or broken sunshell. It is possible to remedy a fluid problem by removing the checkball from its cage in the case in the rear of the trans may help (must remove valvebody), or adding a high-viscosity additive such as Lucas Transmission additive or other seal restorer product. May also have worn boost valve (can replace in the pan).
    2. 1-2 shift does not happen at WOT until you let off the gas: Best case: try replacing the TPS. Middle case: leak in the 2nd gear apply circuit (servo assembly or 1-2 accumulator). Doublecheck by using the pressure gauge and watch for a big drop when the PCM commands 2nd gear. Worst case: poor line pressure rise (see below).
    3. 1-2 Shift shudder at WOT; delayed or abnormal 1-2 shift; There's a problem ONLY on the 1-2 shift: 1-2 accumulator piston cracked or stuck cocked in the bore. Check the yellow spring inside the accum housing for breakage. Also, if the accumulator housing walls are scored, the housing must be replaced. Easy fix in the pan.
    4. 1-2 shift is delayed and harsh, may not shift into OD: Check TPS for smooth and linear electrical response over the entire range of motion. If not, replace.
    5. Trans does not upshift out of first, speedometer reads zero at all times: VSS failure. Easy fix on rear of transmission, but xmember must come out to access VSS.
    6. No 3rd or 4th gear: “3-4” clutches are worn out. R&R. The car is safe to drive (in 2) until you can get it fixed.
    7. Sudden grinding noise with no prior warning primarily in 2nd gear, behavior in reverse may be abnormal; sunshell is fractured. R&R. Try not to run or drive the car or further damage could result.
    8. 1st and 3rd only, no 2,4 or R; sunshell is fractured or splines are sheared off. R&R. Try not to run or drive the car or further damage could result.
    9. No 2nd or 4th gear: 2-4 band is slipping. Servo seals may be damaged (can be fixed without removing trans. Otherwise, 2-4 band is worn out. R&R.
    10. Trans shifts into gear harshly, 3rd gear starts, manual 2nd available but no 1st, no 4th, and no TCC lockup: No power to transmission, or trans is in limp-home mode. Check trans fuse underhood, and make sure transmission electrical connector is plugged in. Easy fix.
    11. No 1st or 4th available
    : trans shifts 2nd to 3rd by itself in D or OD : ShiftA solenoid failed. Easy fix in the pan. Or a wiring problem from PCM to trans.. or PCM.
    12. No 2nd or 3rd available: ShiftB solenoid failed: Easy fix in the pan. Or a wiring problem from PCM to trans.. or PCM.
    13. No TCC lockup:
    Brake pedal switches improperly adjusted (always on), TCC solenoid failed (easy fix in the pan), TCC clutch worn out (must remove trans and replace TC).
    14. TCC always locked: TCC apply solenoid circuit shorted to ground, TCC solenoid blockage (easy fix in pan), or TC broken (must remove trans and replace TC).
    15. Horrible noise in 4th and feels like the brakes are on: overrun clutches are applying due to a cracked or leaking forward piston. Overrun clutches will be worn out after 30 seconds of this behavior. Car can be safely driven in D. R&R.
    16. Soft shifting, gradual performance degradation: Poor line pressure rise due to leaking boost valve, clogged EPC filter screen, failing EPC solenoid, or worst case: leaky seals throughout. Transgo HD2-C kit fixes first two without removing trans. Seal restorer may fix last problem, but probably R&R. Also try a transmission flush with BG brand products (Firestone stocks it).
    17. No forward movement in OD or D, but L2, L1 and R work: Forward sprag is broken. R&R. Try not to run or drive the car or further damage could result.
    18. Extremely harsh shifts from P or N, normal shifts at WOT: EPC (Electronic Pressure Control) solenoid failed. Easy fix in pan. Fix as soon as possible or hard parts will eventually break.
    19. Loud bang, grinding sound, loss of all gears, and a binding driveshaft:
    snapped output shaft. Try to wiggle driveshaft - if more than 0.020" play, that's the sign. R&R.
    20. Trans seems noisy when moving in 1st and Reverse, noise goes away instantly if you shift to N or the trans goes into 3rd gear: Reaction planetary is worn out due to high miles or insufficient lubrication. Not a critical failure, but not a good sign either. R&R sooner rather than later.
    21. No movement in any gear: pump failure, or total loss of fluid. R&R, or refill pan and find the leak. If out of fluid, avoid running the engine until the trans is refilled to avoid pump damage. To check for pump failure, check fluid level with the engine off, then start the engine and recheck fluid level. If level does not go down when engine is running, the pump is broken.
    22. Transmission does not shift automatically, only manually: Swap in a known-good PCM, check wiring, check other sensors such as VSS and TPS.
    23. 3rd gear starts, can manually shift through all gears. When car has been turned off for a bit, then back on it will run normally.: VSS dropoff w/ Hi-stall converter. The rpms are too high, but VSS is showing no movement. Happens after a tire burning take-off. Doesn't store a code, will not throw a CEL (I've heard that it will store a code if it happens 3 or more times). Cure: Reprogram PCM for VSS dropoff -- PCMforLess knows about it.
    24. Car feels sluggish off the line, No 1st, 4th or TCC lockup available, Manual 2nd, 3rd and Reverse are only available gears, CEL is on
    : Transmision is either in limp-home mode or has lost electrical power. If there are lots of error codes in the PCM, check the underhood fuse that powers the transmission, and if it pops again, look for a short in that circuit like an O2 sensor harness touching exhaust. Otherwise, check PCM codes for a particular fault in the transmission causing the PCM to put it in limp-home mode.
    25. Fluid leak out of the front of trans where the converter connects; partial or full loss of movement: Front pump bushing walked out. R&R. May have to replace converter also if hub is scored. Note that a leaking front seal usually means the bushing is walking out (i.e. call your local trans shop and schedule an appt.).
    26. Torque converter shudder in 4th while lockup is engaged, problem goes away when the brake pedal is pressed slightly to unlock converter: Have a shop verify line pressure, and provided no valves in the TCC hydraulic circuit are worn, replace the torque converter. Also, Lubegard Shudder Fix will at least fix this for awhile. Or try a transmission flush by a shop that uses BG brand products.
    27. Shift suddenly become very hard. When going from park to either reverse or drive it slams into gear. 1-2 and 2-3 shifts are also harsh. All gears seems to work. Problem may be intermittent: Check TPS for smooth electrical response. If the response is jumpy or erratic at all, replace TPS.
    28. All fluid pumped out through the vent tube: Plugged cooler line. Flush the transmission cooler and cooler lines. Also could be overfiled transmission.
    29. Car acts like it's in OD in neutral, car is locked stationary in R, engine feels loaded in P, all four forward positions work fine
    :Internal crossleak feeding the forward clutches all the time. Most likely a cracked input housing. R&R required. Car can safely be driven gently in forward gears until the repair.
    30. Needle bearings in the pan, first gear and/or reverse may be noisy: Either a torrington bearing or a planetary bearing is on its way out. Trans will eventually die a loud, catastrophic death. Cheaper to rebuild now (saves further damage to hard parts), but requires R&R. It is drivable until it breaks.
    31. 1-2 or 2-3 shift is slow/soft above part throttle:
    Trans is on its way out. R&R.
    32. 2-3 clunk/ bang under light load, but other gears shift fine:
    Some vehicles may exhibit a clunk noise that can be heard on a 2-3 upshift or a 3-2 downshift. During a 2-3 upshift, the 2-4 band is released and the 3-4 clutch is applied. The timing of this shift can cause a momentary torque reversal of the output shaft that results in a clunk noise. This same torque reversal can also occur on a 3-2 downshift when the 3-4 clutch is released and the 2-4 band applied. This condition may be worse on a 4-wheel drive vehicle due to the additional tolerances in the transfer case. This is a normal condition. No repairs should be attempted. This is a bulletin from GM that i found. it is considered a normal condition. i'd still do the preliminary checks to make sure all driveline components are in good condition.
    33. Gets stuck in third gear but able to be manually shifted through the gears. (No OD). Replacing the 3/2 downshift solenoid in the tranny pan fixed the problem.
    34. When placed in drive, won't start in 1st but then sometimes it will then second and third shakes and then clears up:
    Sprag clutch flipped and broke the cage, but sometimes you can make it flip back over, that's why the death rattle in 2nd and 3rd.
    35. No 2nd and 4th? but has reverse: The 2/4 band is broken, not applying, or burnt to a crisp.
    36. Whistling noise from transmission: Teflon wore off your pump bushing. they wear off, and make a funny little buzzing sound, then when you put it in gear, the pressure goes up, and the torque converter is pushed forward slightly, and then no noise. The sound is temperature temperamental too.
    If you see any changes or any other ideas, just add them to the list.
    E85 is NOT flex fuel.
    2003 Chevy S10 4.3L LU3 LS1B Auto
    48 LB injectors
    Race Proven Motors 2114 intake
    T70 turbo.
    Senior Member blsnelling's Avatar
    Sep 2010
    Hillarioius. I just ran across this a few minutes ago searching about limp mode
    May 2008
    Yeah, I've found it posted like 15 times, but no idea where it came from.
    48 LB injectors
    T70 turbo.
  1. Amp draw causing 4L60e problems...
    By Blade_1 in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: June 6th, 2009, 03:24 AM
  2. 4l60E / T42 TC lockup problems
    By harascho in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: February 16th, 2009, 06:34 AM
  3. 4l60e question
    By chris98z71 in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: January 20th, 2009, 10:54 AM
  4. 4l60e problems
    By chevyman98 in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: April 20th, 2008, 02:21 AM
  5. 4l60e tranny shifting problems
    By vettenv in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: April 18th, 2006, 03:39 PM
