Sooo, I am working on gathering information on how to run a 58x setup on a non-LS motor. I need a better understanding on how it triggers, how to set the alignment (orientation based on crank position) TDC? Will a CASE re-learn figure it out on its own?
How about the 4x CPS? how is that set in relation to the cam(s).
In this case, I am working with a DOHC I6 and will utilize the LL8 E67 ECM/OS.
Any help will be great!
Thanks,
David
