Results 1 to 6 of 6
Thread: Trying Calc.ve--need help
    Jul 2009
    Default Trying Calc.ve--need help
    I've been trying the Calc.VE tutorial, set everything up ...apparently wrong.
    Followed this thread a bit
    http://forum.efilive.com/showthread....etting-started
    Using weathermanshawn's calc_pids.txt(thanks)
    I have a AEM Uego W02 hooked up to the V2 w/ a serial cable.
    Went for a short drive just to make sure I set things up right, my maps don't look right, and I can't figure out why
    I already changed the precision to 4
    Setup wise its a '98 suburban k1500 with an 0411 swap, stock 5.7 (so far)
    any direction is greatly appreciated.
    thanks!
    Jul 2008
    On the menu tabs you have 'N' selected' instead of X.
    N just gives you the number of samples, X gives you the average..You want X for the actual value..
    Jul 2009
    Quote Originally Posted by WeathermanShawn View Post
    Thanks shawn, I was in a rush last night and posted the wrong pic, I was playing around and changed a few things, so I'll do another run today. this is with it on the X
    How do I totally delete a map and start over? If I clear the current, the data is still in the properties box...
    Jul 2008
    Try this Tutorial..http://download.efilive.com/Tutorials/Interactive/How to Create a Map.htm
    Some guys can explain it step by step (better than me), but I used all the Tutorials when I first started. Much better to learn step-by-step.
    A new log should also give you fresh data. Make sure you have the proper pids selected for CALC.VE Table..http://download.efilive.com/Tutorials/PDF/Calc.VE Tuning Tutorial.pdf
    Good luck..
    Jul 2009
    Whatever I changed last night helped, then I had to change the VE_table to % looks a little better
    Jul 2008
    Looking better!
    Don't forget to review all the Tutorial discussion and any threads you can on filtering out Throttle Transients etc.
    Thats 75%+ of constructing a good CALC.VE Table..
    Keep logging..
  1. Calc.ve
    By whackem04 in forum Gen III V8 Specific
    Last Post: October 1st, 2009, 03:14 PM
  2. Calc.Torque
    By purrvert in forum General
    Last Post: May 10th, 2007, 03:32 AM
  3. hp calc PID
    By pwilson22000 in forum General
    Last Post: July 25th, 2006, 12:58 AM
  4. CALC pids
    Last Post: October 25th, 2005, 12:32 AM
