Results 1 to 4 of 4
Thread: Question
    Jan 2008
    Default Question
    I have a 06 1500HD with a Radix and the superchips tune that comes with the kit. Can I copy the superchips tune with EFIlive without any issues?
    2006 GMC CCSB 1500HD 4X4 - Radix 3.2 pulley, Pacesetter Long Tubes, Magnaflow exhaust
    Nov 2007
    You could, but most likely it will have been locked by Superchips.
    I believe so, but honestly why bother? If you have EFILive then you should build your own tune that is going to be 10x better than the superchips canned one. Maybe read out the superchips one for reference to see what (read how little) they change, flash it back to stock with superchips then read with EFILive as your base tune.
    Jan 2008
    I would build my own tune but I really don't know how to use EFILive. I was hoping to copy the superchips tune to give me a baseline that I know works.
  1. Desired Airflow Question, not your normal question
    By Dale in forum General (Petrol, Gas, Ethanol)
    Last Post: October 1st, 2010, 11:10 AM
  2. Locked out timing question for boost setup question??
    Last Post: September 13th, 2005, 03:22 PM
