I didn't scale the map, I thought that this would throw me back into the same predicament as I was having before, with the injector scaling. I was under the impression that this scaling was only used for the 2 bar os. Thing is, I really have made minimal changes (intercooler piping and running my air filter outside the engine compartment) and it was running ok before. The only major change was the th400 swap, which I can't relate to the misfire, right?
the misfire is VERY apparent. there's no mistaking it's there in the 50% throttle range and it's definitely there in the 25% load range, just like a slight bump every few seconds/ minutes. Have you ever had any experience with an old worn out 2 stroke outboard? I can compare this to the way that one of those runs when the carbs are gummed up.
I did check rockers, springs, and push rods. I still have the .025" preload on each lifter. The compression check was satisfactory in my opinion; 180ish, on all cylinders as I recall. The lifters are stock GM CTSV lifters. I can't recall the part number but they were recommended in several FI builds on various sites. The pushrods are hardened comp cams stuff.
I checked each coil by using the old screwdriver in the plug wire boot trick. All of them jumped gap to ground evenly. I did check each injector at idle to see if it was missing without me hearing it, I used the controls in the scan tool to cut each one sequentially and checked for tone change, i could distinctly tell when i cut an injector on each of the cylinders. so there is no miss at idle, and It's so hard for me to say if it is missing at WOT, because all hell is breaking loose, and I get tunnel vision, lol....... I don't think it is missing at WOT, I checked a couple of videos I had of it from earlier this year (in car) and it sounds the same to me, video to video.
The logfile is going to show the car running very rich, don't be too surprised when you look at it. it's the very first AutoVE. Nothing was changed in the tune except for raising the VE table 10% or so from the old tune
