Results 11 to 20 of 22
Thread: misfire with no codes, need help please!
  1. #11
    Feb 2007
    I didn't scale the map, I thought that this would throw me back into the same predicament as I was having before, with the injector scaling. I was under the impression that this scaling was only used for the 2 bar os. Thing is, I really have made minimal changes (intercooler piping and running my air filter outside the engine compartment) and it was running ok before. The only major change was the th400 swap, which I can't relate to the misfire, right?
    the misfire is VERY apparent. there's no mistaking it's there in the 50% throttle range and it's definitely there in the 25% load range, just like a slight bump every few seconds/ minutes. Have you ever had any experience with an old worn out 2 stroke outboard? I can compare this to the way that one of those runs when the carbs are gummed up.
    I did check rockers, springs, and push rods. I still have the .025" preload on each lifter. The compression check was satisfactory in my opinion; 180ish, on all cylinders as I recall. The lifters are stock GM CTSV lifters. I can't recall the part number but they were recommended in several FI builds on various sites. The pushrods are hardened comp cams stuff.
    I checked each coil by using the old screwdriver in the plug wire boot trick. All of them jumped gap to ground evenly. I did check each injector at idle to see if it was missing without me hearing it, I used the controls in the scan tool to cut each one sequentially and checked for tone change, i could distinctly tell when i cut an injector on each of the cylinders. so there is no miss at idle, and It's so hard for me to say if it is missing at WOT, because all hell is breaking loose, and I get tunnel vision, lol....... I don't think it is missing at WOT, I checked a couple of videos I had of it from earlier this year (in car) and it sounds the same to me, video to video.
    The logfile is going to show the car running very rich, don't be too surprised when you look at it. it's the very first AutoVE. Nothing was changed in the tune except for raising the VE table 10% or so from the old tune
  2. #12
    Wow, pretty wild...
    I looked more closely at your wideband AFR, it is alot over rich... you're probably getting rich misfire...
    Remove the plugs and see if they're all wet... what gap are you running...?
    Do you get the rich exhaust smell...?
    It's probably not missing at WOT.
    You're using the LC-1 calc pid for your PLX, is this correct...? Is the voltage->AFR function AFR = V*3 + 7.35...?
  3. #13
    Do you have FlashScan V1 or V2...?
    If V2, then you should really be using serial comms to obtain AFR.
  4. #14
    Feb 2007
    I'm using V2. I am using an AEM wideband. the Calc PID for it is the PLX. I accidentally logged the wrong one; my brother's running the LC1 on his Firebird. I swapped the calc pid after i opened the log file when I got back home and it shows the proper AFR. I think it defaults to whatever I logged it with? I don't have any provisions for serial comms with the AEM, but I can swap my AEM in my car for a PLX, I have one in my 75 Bronco. it does have a serial port on the converter box I think. What would this do for me as far as accuracy? Plug gap is between .035" and .038" brand new plugs were used in this log and I did pull them out after the log and they were not wet. They just had a hint of blackening (soot) because of the rich condition.
    I believe the calc pid for the PLX is - AFR = (V*2)+10?
  5. #15
    V2 supports serial comms AFR from AEM UEGO.
    I'm not sure how you connect it to V2, but there are only two possibilities:
    - straight serial cable,
    - null modem serial cable;
    there's a thread on here somewhere for AEM.
    Serial comms means V2 obtains the AFR from the wideband in digital form and so avoids AFR-to-analog translation/detranslation and analog voltage offset errors associated with that.
  6. #16
    Feb 2007
    I bought my V2 3 years ago, I don't remember this cable being included. Is it an additional item that I need to buy or was it probably included, and I just don't remember seeing it?
    By the way here is the AEM hookup sheet for serial connect.
Name:	AEMWB02 serial connection.jpg
Name:	V2 serial connection.jpg
  7. #17
    Your V2 came with the 3 cables shown in your pic.
    You need this cable (see the 4th one down): http://taquickness.com/taqcables.htm
    You will need to update your V7 and V8 software from here (scroll down): Download Software
    You will also need to update your V2 firmware and bootblock, please read attached doc carefully before proceeding.
    What version firmware and bootblock does your V2 currently have...? This will determine what you have to do from the doc.
  8. #18
    Feb 2007
    see my software versions below.
    I remember reading that document and going through those steps when I upgraded a while back. my versions should be sufficient, eh?
    I'll see about getting that serial connection up and running. I feel much more comfortable with the idea of having a better handle on what my car is running the A/F department.
    Can you suggest anything else that I would need to log, that I havent been, that might help in finding the misfire in the event that it's not an A/F ratio issue?
    Like I said before, when it's put into closed loop the fuel trims do bring it back to a 14.7ish cruise, and the miss is still there. I just want to try and get it narrowed down a bit before I take it back out on the road. That's quite a bit of money under the hood sputtering and missing, Lol!
    I'll post up as soon as I get the serial connection hooked up and get a log file uploaded; hopefully we'll make some sense of all this.
    One more thing, I really appreciate your taking time to help me on this problem, it means a lot! I haven't gotten any help at ls1tech or the gto boards.
  9. #19
    You are correct, your software/firmware versions are sufficient, you're at the latest.
    All you need is the cable mentioned in post #17.
  10. #20
    You can also log the misfire pids, these attempt to identify the cylinder that is misfiring... you may want to do a CASE relearn first.
  1. misfire problems
    By Gregs in forum Petrol / Gas
    Last Post: June 25th, 2010, 01:45 AM
  2. Mystery Misfire codes?
    By Mr. P. in forum Gen III V8 Specific
    Last Post: November 5th, 2009, 05:46 AM
  3. Getting Rid of Engine Misfire Codes
    By RandomHero in forum General (Petrol, Gas, Ethanol)
    Last Post: January 9th, 2007, 05:55 PM
  4. misfire help
    By NviouSS in forum General
    Last Post: June 3rd, 2006, 06:18 AM
  5. Misfire Table
    By Honez in forum General (Petrol, Gas, Ethanol)
    Last Post: February 1st, 2005, 01:19 PM
