The attached file has three things happening that I need stopped.
Thing #1: AFR event frames 4915 - 4988 & 8652 - 8667 (Edit: When these events happen, the car snaps from closed loop to open loop for the event and then goes back to closed loop)
One occurs at idle (and often I might add) that I can feel and one happened at 37MPH which I could not feel. When it happens at idle, my idle dips pretty heavily (400's) It was not pronounced on this recording but I can feel the Power Steering shudder when the event occurs.
Thing #2: KR. In open loop, my shifting has 0 KR. After the car gets hot and in closed loop, it goes into KR especially at 3rd gear.
Thing #3: Idle dip to very low RPMs when clutch is depressed as in coming to a stop.
Open loop
frame 776 RPM 496
and 1216 RPM 376
Closed loop
frame 3905 RPM 444
This is constantly happening and the dives in RPM affect the Power Steering enough to make the steering wheel to shudder.
Ok, that's it.
TIA,
Elmer
