Results 1 to 10 of 15
Thread: Known issues in V7.1.16
    Default Known issues in V7.1.16
    The following is a list of confirmed issues with the current release of the EFILive V7.1.6 software.
    We are working on an update (V7.1.7) to fix them. The update will be ready for beta testing in the next day or two. We expect that V7.1.7 will be released sometime soon after that.
    Known issues in V7.1.6 public release
    Problem:
    A small set of PCMs cannot be unsecured by EFILive. This prevents any reading or reprogramming of those PCMs.
    Temporary workaround:
    None.
    Status:
    Fixed in V7.1.7
    Problem:
    Save icon is not enabled after loading a PCM calibration with an unsupported operating system
    After loading an unsupported PCM calibration, click on the "Show blending and smoothing window" toolbar icon and close the window. That process will refresh and enable the "save as..." toolbar icon.
    Status:
    Fixed in V7.1.7
    Problem:
    Uploading black-box logging can fail for various reasons - usually due to data checksum errors. EFILive should discard the frame with the checksum error and recover with the next frame. Instead, EFILive is bailing-out on the bad checksum and not attempting to recover.
    Temporary partial workaround:
    Configure the FlashScan cable with the Validate PIDs option. That will reset the black-box logging memory. Then reconfigure the FlashScan cable with the PIDs you wish to log and retry black-box logging.
    Status:
    Fixed in V7.1.7
    Problem:
    If a PCM has a blank VIN, EFILive Scan Tool is not handling it correctly.
    Don't use PCMs with blank VINs.
    Status:
    Fixed in V7.1.7
    Problem:
    Reading a PCM can take too long. EFILive will drop down to 1X speed if it encounters too much noise on the class-2 data bus. It should only drop down to 1X mode after a number of failures at 4X. Currently it is dropping down on the first failure.
    None.
    Status:
    Fixed in V7.1.7
    Problem:
    FlashScan's MEM LED is not being extinguished after reconfiguring the black-box logging. That process clears the log files and should extinguish the MEM LED.
    Power down FlashScan
    Status:
    Fixed in V7.1.7
    Problem:
    Some operating systems are not supported.
    Please send your unsupported operating system *.tun files to support@efilive.com and we will add them as soon as we can.
    None.
    Status:
    Some new OS's will be added in V7.1.7
    Problem:
    Toolbar customization checkboxes are grayed out and cannot be used in the Scan Tool.
    None.
    Status:
    Fixed in V7.1.7
    Problem:
    Can't easily copy data (without data labels) from maps in Scan Tool. Standard Copy feature is incorrectly implemented as Copy Special.
    Paste data into Excel and re-copy only the data that you require.
    Status:
    Fixed in V7.1.7
    Problem:
    Ok and Cancel buttons do not work in Customer Details window of the Scan Tool.
    Use the [X] button in the window ttitle bar to close the window.
    Status:
    Fixed in V7.1.7
    Problem:
    Speedo calculator did not include "Vehicle speed ratio" - required for corvettes due to their transaxle configuration.
    None.
    Status:
    Fixed in V7.1.7
    Known issues in V7.1.7 RC2
    V7.1.7 RC2 (release candidate 2) is currently being tested by the beta test group. The following issues have been reported and will be fixed prior to the public release.
    Problem:
    Built in wide band O2 PIDs for TechEdge and PLX have default limts of 0..5. This should be changed to 9..19 for TechEdge and 10..20 for PLX
    Change the limits specified in the sae_generic.txt file for the following SLOTS:
    Code:
    *CLC-00-908
    V                  0.0           5.0       .1  "{EXT.AD1}"
    AFR                9.0          19.0       .1  "{EXT.AD1}*2+9"
    *CLC-00-909
    V                  0.0           5.0       .1  "{EXT.AD2}"
    AFR                9.0          19.0       .1  "{EXT.AD2}*2+9"
    *CLC-00-910
    AFR               10.0          20.0       .1  "{EXT.AD1}*2+10"
    *CLC-00-911
    AFR               10.0          20.0       .1  "{EXT.AD2}*2+10"
    Status:
    Fixed in V7.1.7 RC3
    Nov 2004
    Any news on an eta?
    Been a busy week - the updated software should be available before the weekend.
    Fixed a bunch of bugs listed above.
    Finally ironed out the glitches in the speedo calculator - thanks to jpilla and his expertise.
    Ross also squeezed some extra spark PIDs in that make it much easier to to tune the spark tables.
    The seed/key problem is sorted and you should be right to go by Friday.
    Sep 2004
    Good news Paul, So was the problem with the speedometer calibration on my truck related to software? I sent my .tun file.
    Thank you again for all your guys hard work. I love the program... And your great support makes it soooo much better...
    \'04 Z16 Corvette, AFR 205 heads, Comp 228/232 114+4 LSA custom cam, HS Rockers, Kooks 1 7/8\' headers, 3\" X-pipe, stock Ti tail section. \'98 Corvette Pace Car, \'04 Chevy Avalanche Z71 4X4.
    Quote Originally Posted by Z16DNA
    It could possibly be related, I did not get any email with a *.tun file attached. Can you try sending it again to paul@efilive.com. I will check it with the new speedo calculator.
    Lifetime Member emarkay's Avatar
    Paul, see a few probs with email file attachments and the like.
    What ever happened to the password protected ftp server?
    Or maybe a private filetransfer web page - I know there are a few out there.
    Just an idea.
    MRK
    Sep 2004
    Paul, re-sent it from my home account. Hopefully it makes it through.
    Quote Originally Posted by emarkay
    Just an idea.
    MRK
    Hmmm, good idea to get the ftp area active again.
    Got it thanks - I'll take a look a bit later.
    The speedo settings in your *.tun file appear very messed up. Is that file the original factory tune that came from your PCM?
  1. What have the issues been with LMM'S?
    By LBZoom in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: September 22nd, 2009, 02:06 PM
  2. A/C issues
    By Naf in forum Gen III V8 Specific
    Last Post: June 15th, 2009, 12:07 AM
  3. 2 bar E38 issues
    By XLR8NSS in forum E37, E38 & E67 PFI ECM's
    Last Post: May 1st, 2009, 03:51 AM
  4. KR log issues
    Last Post: October 3rd, 2008, 11:58 AM
  5. Ok some serious issues
    By Highlander in forum FlashScan V2 BB Logging
    Last Post: March 23rd, 2008, 05:45 AM
