2002 Silverado 8.1L L18 with 5 sp Allison auto trans.
Anybody know if the value of the cell B1901 is merely used for calculating in other areas or does it actually limit your max torque?
I have disabled axle torque limiting B6601, but the value entered into cell B1901 only seems to affect how the trans up-shifts. e.g.: value of B1901 set to 50 and the trans bangs the shifts very very hard, if you set it to 640 which is max, it up-shifts very very soft. I assume it affects the % of torque reduction on the up-shifts, but I want to know if setting B1901 to 640 max allows more engine torque or is it really infact limmiting more torque?
thanks.
