I have a 99 TA with OS 09360361 and the IAC correction pids won't validate so I can't do the idle transition tuning really. Am I missing something or is that just how it is and I'm crap out of luck? Thanks.
What operating system number is the PCM? (Doh! I just re-read the post)Originally Posted by camdavgar
I'll find out what the support for IAC PIDs is for that OS.
Do you mean the 09360361 or another? I don't know what else you could mean.
Some (but not all) of the IAC PIDs are valid for that OS.
If you are not connected to your car, EFILive may not "know" what operating system you want to scan. You can select your OS by menu option: File->Enter VIN.
You should always make sure the VIN and OS are displayed correctly in the status bar at the bottom of the Scan Tool window.
Sounds good. I've tried validating several times. I got some help earlier from black02ss and came to the conclusion that they just weren't available for my OS. Thanks for taking the time to help though, I appreciate it.
I've had this same exact problem as well with 1250002 custom OS, any ideas??
I need them for idle tuning as well.
1992 Turbo LSX Notchback Mustang 275 radial car - under construction
2008 Sierra 2500HD Duramax
Any word? I really need these PIDs
