Results 1 to 10 of 15
Thread: E39 SIDI L4 turbo
    Oct 2010
    Default l4 turbo
    Thank you
    3onic
    Hi there 3onic, the E39 ECM in the 2011's is 'slightly' different to the 2010, the read does fail on these, we just started getting a few instances of this through support. We are testing a fix in the field now and will release it very soon once it's confirmed working ok.
    P.S - I am impressed you have access to one, they aren't showing up in many places yet.
    To follow up, the read fix has been tested on a 2011 LHU car, we will release an update soon.
    Oct 2010
    Great news, thank you very much
    Oct 2010
    Hi
    I tested the latest release and could read the ECM. This worked fine
    So I took a look at the calibration and saw that there are no maps under the "torque control" or VE under "airflow". How should I be able to tune something?
    Sorry, but I'm new to EfiLive and perhaps i miss something.
    Anyhow I tested the car on the dyno with a Lambdameter and saw that at WOT the enrichment goes to Lambda 0.83. It does not match 100% to the PE Enrichment map: is this usual or strange?
    Thank you very much for your help
    Dec 2005
    Quote Originally Posted by 3onic View Post
    Hi
    any chance you'd share then lhu file? I've been wanting to take a look at one for a potential project... pm me if you like.
    98 Chevy truck RCSBFS 2wd/5.7L/4L60E:drive:/Paxton Novi 2000 S/C @ 7psi / Megasquirt
    72 Chevelle LQ9/4L80E/GT42 conversion in the works
    http://www.ls1tech.com/forums/showthread.php?t=449129
    Nov 2007
    Would you be able to post up the stock tune?
    I'm surprised you were able to see the maps, we have not seen a file from one of those cars yet so it just must have been luck it was the same OS used on another vehicle.
    Dec 2008
    Just read a 2011 Buick turbo, holy cr#p I wish we had all these tables on the LNF! (Bosch E69) Just glanced through it a little, it did seem to read out fine. Lots of maps with lots of weird stuff! (Estimated Compressor Speed, Multi-Spark, etc.) There is a flash counter and it also shows the last time it was flashed by GM.
    Oct 2010
    Quote Originally Posted by gmtech16450yz View Post
    Great! So we are two now "playing" with this new engine.... Could you find something like torque maps to increase?
  1. New ECM to test read - E39
    By GMPX in forum FlashScan V2 BB Logging
    Last Post: November 11th, 2015, 04:27 PM
  2. E39 , E78 ECM tuning almost done
    By GMPX in forum E39, E80, E82 & E92 SIDI ECM's
    Last Post: September 15th, 2011, 03:18 PM
  3. E39 & E78 Custom OS's on the way
    Last Post: October 11th, 2010, 10:16 AM
  4. Closing turbo vanes for turbo braking?
    By Haulinbass02 in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: May 14th, 2009, 12:12 PM
