Results 1 to 8 of 8
Thread: P11 Ecotec 2.2 {G0915}
    Aug 2008
    Default P11 Ecotec 2.2 {G0915}
    I'm using this pcm as a standalone....Can someone explain what this does? If I enable it, does that mean the electric fans will turn OFF & ON at the temps I choose? If it's disabled, does that mean it has a mechanical fan?
    FLASHSCAN V2 & AUTOCAL
    Aug 2008
    Anyone?
    Is anyone even flashing these pcm's?...
    It is used to disable the fan clutch in the P10 PCMs (tested it works on my 02 TB P10), but thinking about it most (if not all?) P11s have efans anyway as they are transverse mounted, right?
    So: Disabled = fan clutch
    Enabled = electric fans
    But if you're not getting lights and its disabled and you have efans already, who knows?
    Aug 2008
    The stock tune had it disabled and fans wouldn't kick on at all, or they would kick on but at the wrong temperature and they wouldn't shut off at all...
    So I enabled the electric fan parameter & did a full flash and fans are working perfectly...
    Quote Originally Posted by GAMEOVER View Post
    Cool! Also, you can full flash the P11s? Dang it, the P10s cant because of the way the ETC CPU communicates with the regular CPU. HPTuners can do it though, unfortunately.
    Aug 2008
    A buddy of mine told me they can put the P11 into Open-Loop and tune for Big turbo's too...
    Might have to invest...
    I dont wanna drop $400 on their "stuff", EFILive's hardware is a generation ahead and we have more than just BBL functions. Id ask on their forum for some screenshots of their parameters to see if they actually can do what you want. Maybe someone close to you has a cable and will let you take a look and play with it?
    Aug 2008
    Yeah, I didn't think of asking him to let me play with it first...hehehe
  1. Ecotec files
    By slows10 in forum IL6,IL5,IL4 Atlas Engines - P12 PCM
    Last Post: January 10th, 2011, 09:16 AM
  2. unsupported ecotec pcm
    By Gregs in forum IL6,IL5,IL4 Atlas Engines - P12 PCM
    Last Post: August 24th, 2010, 03:23 PM
  3. Holden Vt V6 ecotec - help
    By andy_h83 in forum EFILive V4
    Last Post: May 6th, 2010, 07:51 AM
  4. Anybody have a stock file from an ecotec 2.4L?
    By antivenom in forum E37, E38 & E67 PFI ECM's
    Last Post: June 3rd, 2007, 02:40 PM
  5. Ecotec in a miata
    By finiata in forum General (Petrol, Gas, Ethanol)
    Last Post: November 22nd, 2006, 09:43 AM
