i've been having a lean issue up to 1500 rpm or so ever since i had my car tuned by a very reputable tuner in April. i've done logging for him on several different occasions & apparently he can't figure it out. i'll post the log & the tune & let you guys check it out. the car is mechanically fine, good fuel pressure, no vacuum leaks, leakdown & compression tests performed. i'm sure there are no issues with the car & feel it has to be in the tune. let me know what you guys think.10.19.1.tun10.19.10 ColdStartWarmup.efi10.19.10 DriveAroundTown.efi
