Results 1 to 3 of 3
Thread: E67 STFT Overshoot
    Jul 2003
    Default E67 STFT Overshoot
    Is there a way to control the overshoot for the STFT on the E67. I am tuning a ZR1 that is "hesitating" and it's due to the overshoot. You can see in the wideband that it oscillates between 14 and 16 in the overshoot while cruising at a constant speed and rpm in closed loop. This is very annoying and I wish to solve this. Anyone know how to do this?
    On the LS1 PCM i could change the airflow modes at least and that gave me a way to change the overshoot, although we do have access to the multipliers for this.
    Is this a problem with the close loop algorithm or a problem in my tune perse?
    Anything I should look at to avoid this hesitation?
    Funny thing with bigger cams and the ls7 (maybe because it's a bigger engine) I don't get this issue. The overshoot has very little effect on the engine's stability.
    Dec 2007
    Is this overshoot there stock, or is the engine modified now?
    Hesitates at cruise? What does the log of STFT look like?
    Jul 2003
    Yes... there was always an overshoot.. but with the stock cam it's really not noticeable and since the reaction of the engine is much faster to fueling changes, the overshoot is less...
    When you go higher than 2000rpms (you are getting into a better efficiency zone for the cam) the overshoot is a lot less and you can see a more steady mixture from the wideband and less overshoot with the stft.
  1. Question about STFT
    By pauly24 in forum General (Petrol, Gas, Ethanol)
    Last Post: July 2nd, 2010, 12:39 PM
  2. STFT Idle
    By Mort in forum Custom Operating Systems
    Last Post: October 17th, 2009, 02:46 AM
  3. stft problem
    By drdarthinvader in forum Gen III V8 Specific
    Last Post: June 29th, 2009, 12:22 AM
  4. Logging STFT
    By Lextech in forum Petrol / Gas
    Last Post: May 4th, 2009, 11:38 AM
  5. stft
    By 69camaro5speed in forum Custom Operating Systems
    Last Post: April 8th, 2008, 02:39 PM
