Hi everyone,
Car is vette 99 with 408 engine, H/C, F1-A procharger 14 psi.
Look at the log of this car, has a lot of stuff to be corrected:
- Fuel injectors needs to be replaced with a higher size " will go for 80 vs current 60"
- Mass air maxes out around 4200 rpm, will go for lingenfelter 100mm vs Z06 "OME# 25168491". Anybody tried it before, please advise if it good or not.
- Fuel pump needs to be replaced, from dyno graph "will be attached later" fuel pump fails to deliver the required fuel. Racetronix with KB BAP, still I am looking for good replacement, door is open for ur suggestion.
Run.efi
