Thanks for the additional information ... helps to sort things out ... mentioned your speedometer to not accurate .. this will effect the pulse generator output. Mentioned it was out by "10 MPH" ... looking for a percentage to figure out proper values ... 10 MPH at 60 MPH (ie. shows 60 MPH when the actual vehicle speed is 70 MPH) ? Tire diameter is exactly 38 inches per the manufacturer ?
Will then try and come up with values to improve VSS accuracy.
Regards,
Taz
