No need for the analog wires unless you want them.
LC-1 WBO2
With this cable (serial comms), there is no need to connect the yellow or brown wires to V2;
( the yellow wire can be used to provide an NBO2 emulation signal to the PCM; the brown wire can be used to drive an analog gauge )
Serial comms connection gives you the pids WO2AFR1, WO2LAM1, WO2EQR1, WO2ST1, BEN1... use these instead of the AFR/BEN pids specific to a wideband.
Speaking of serial BEN, how about adding a serial EQ BEN to the next software update.
PHP Code:
#Units Low High Fmt Expression
*CLC-00-007
factor 0.00 2.00 .2 "({GM.EQIVRATIO}/{EXT.WO2EQR1})"
#Code PRN SLOT Units System Description
CALC.EQ_BEN F007 CLC-00-007 factor Fuel "EQ BEN"
LC-1 WBO2
I followed the instruction for the TAQ cable, as linked in the first post. I can watch my AFRs realtime on the V2, so I know the LC1's working.
I've now gone into Scan Tool and created both the AutoVE map and Average AFR map.
I've already finished a CalcVE tune. Where do I proceed to from here to tune my WOT AFRs and spark?
Are you planning on running MAF'd...?
If so, then do AutoMAF tune...
to do AutoMAF, follow AutoVE but with: MAF enabled, B0120 set to 400 rpm, and create a BEN map that matches B5001 (use Paste Labels).
After airmass source has been wideband corrected (VE and/or MAF, depending on what you plan on running, SD or MAF), the wideband AFR matches the commanded AFR...
so you simply set the desired WOT AFR in B3618 (and enable PE)...
if you have dyno time: first adjust the WOT AFR for best torque... then adjust spark to lowest timing that gives best torque without knock...
LS heads have fast burn chambers so timing typically is less than SBC.
Here's my first log with the LC1. I was concerned about going lean at WOT, but am actually a little rich. I am getting considerable KR though, 8.0. Is it normal to go that lean on decel?
AFR_001.efi
Wideband shows your WOT has a suitable AFR, but wideband AFR does not match commanded AFR, so need to filter and apply this BEN to the VE table (if this log was taken while running OLSD).
The large lean jumps on decel are due to DFCO being enabled... I usually disable DFCO during tuning, but you can filter it out.
You might try going a little richer, say to 12.5, to see if the knock stops... was the knock audible...?
Your KR waveform doesn't have a tight sawtooth pattern (it shows a minor sawtooth pattern, but it doesn't seem like knock to me).
I see a consistent KR jump when above 6000 rpm, might be valvetrain noise, or something.
