As the title states, having an issue with the attached tune. It has been scaled for 80 lb injectors and running a 2 Bar MAP. Got most of the tune done but when I went to 6000 RPM, experience a severe drop out in Dynamic Air. Tightened belt but MAP (and Boost) were holding? Even stranger, when the PCM "burps" (see 15:53:02 in attached log), subsequent restart result in very rich idle (commanded still good) and she won't take any gas.... bogs, sputters etc. Seems only a complete reflash (2 Bar OS and calibration) will correcte the situation. But the pull after that shows the same "burp" and the cycle repeats. Seems like it is overwriting the PCM or something?????? The is also some timing being pulled at 16:52:59 which I am searching for.
Any help would be appreciated...thanks in advance
Ed M
Main VE adj after steady state log_fixed timing table iAt 50pct ve max inc 0000_0002.tun
