Had a 01 LB7 come in for DSP5 tuning. OP sys is 15166853. Then when I upgrade it to dsp5 it becomes 02685305. So that's correct. I ran the LB7 Late DSP5 script. The problem I'm having is once I full flash it into the ecm the ECM losses communication and the ignition relay and grid heater relays click on and off very fast. Then I can't do anything until I remove the switch from the blue connector on the ECM. I verified the pins where in the right holes and that the switch was working properly with a ohm meter. Any ideas what would cause this? When I pull the codes U1016 loss of communication with PCM comes up.
