Hi,
I was trying to access freeze frame data of a DTC for a E40 ECM and keep getting an message indicating it's not supported in the current version of EFILive. Is this true? I thought that was odd because it works fine for LS1 PCM's. Thanks.
Hi,
Which build version of scantool (do Help->About)...?
V7.5.6 Build 117 I just updated it a couple of months ago.
Build 133 was the most recent, build 136 expected shortly.
Regards,
Taz
Now I remember, I don't think FF data can be retrieved for any CAN ECM in V7, it can be done via the V2 though. I just checked it on an E39 and E38 and it worked OK from the V2.
On V2:
- Connect to the ECM
- On the keypad press F3 (Diagnostics), F2 (Trouble Codes), F3 (Display FFs) and then select the controller you want to query
Andrew
EFILive Crew
Thanks for the response Andrew. That's the message it displayed. I checked the FF data using the V2 and didn't see any info displayed. I will check again, maybe I missed something.
