Results 1 to 4 of 4
Thread: Tune doesn't go lean anymore
    Jun 2008
    Default Tune doesn't go lean anymore
    Hi all,
    I recently discovered through the AUT-VE process that somehow my commanded AFR won't go leaner than 14.63 although I'm in open loop and have lean cruise cells in my B3647 table. Somehow the tune doesn't reference anything leaner that stoich anymore.
    I have been doing normal cal flashing for some days until I noticed this.
    Is this a bug in the program or did I enable/disable anything that I'm not aware of.
    Here is a recent log and tune.
    Should I do a full flash to make sure everthing gets cleaned out?Alex_baseline COS5 _0217_ new_new_IFR.tunBB-Log_0390.efi
    Alex
    Jun 2008
    UPDATE:
    I resolved the issue by myself with comparing the current tune with an older, functioning one. I had put the values in B3619 to 14.63 which messed everything up. I now put them back to 14.7 and everything shows up fine.
    Alex, thanks for the update (I previously read your post, I didn't have an answer).
    You mean in B3618...?
    Jun 2008
    Yes it is B3618 instead of B3619.
  1. lean tune
    By southern in forum Gen III V8 Specific
    Last Post: September 23rd, 2010, 10:27 AM
  2. Timing in tune doesn't match log...
    By LS1FREEK in forum Gen III V8 Specific
    Last Post: August 28th, 2010, 08:43 PM
  3. Need some help: Can't view Dashpage anymore
    By DrkPhx in forum General
    Last Post: November 28th, 2009, 01:23 PM
  4. Running lean after tune
    By SRT10KLLR in forum General (Petrol, Gas, Ethanol)
    Last Post: March 16th, 2009, 07:06 AM
  5. NEED HELP running lean after tune!!!
    By clg82 in forum Gen III V8 Specific
    Last Post: February 25th, 2009, 07:30 AM
